Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Modèle A1278 mi-2010 / processeur core 2 Duo à 2.4 ou 2.66 GHz
Are Torx Security bits compatible with non-security bits?
I am looking to upgrade my wife's old Macbook Pro with an SSD, following this guide: Remplacement du disque dur du MacBook Pro 13" Unibody mi-2010
It says we need a T6 Torx screwdriver. I thought it was weird that the driver kits being sold by iFixIt wouldn't include anything higher than T5 for non-security Torx bits, but then I saw the following on this page: TR6 Torx Security Screwdriver
"Security drilling on this driver makes sure that you won't be stopped by anything, even though this driver still works great in non-security T6 screws as well."
So, can anyone confirm if Torx Security bits are compatible with Torx non-security bits, and does this hold true for all Torx bit sizes?
Image Precision fixed blade screwdriver engineered by iFixit.
Produit
$5.99
Répondu ! Afficher la réponse J'ai le même problème
Indice 9
Ajouter un commentaire
2 Réponses
Solution retenue
The difference between security torx and standard torx is the hole drilled in the center, this allows the driver to slip over the pin located on the security screws. Otherwise they are identical sizes.
Indice 5
1 commentaire:
is just the hole the difference? both share the same sizes?
par
Réponse la plus utile
Of course they are, all it is, is an extra hole.
Indice 7
Ajouter une réponse
Help Computer sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 9
30 derniers jours : 34
Total : 25,225
