The appropriate system storage
My PlayStation won't go to the home screen won't do anything but say cannot start the appropriate system storage was not found. What do I do
Most likely the hard drive has gone bad.
You could try reseating the system storage drive which is located inside a compartment on the side of the PS3. It will require a phillips head plus screwdriver to take out the hard drive secured to the hard drive cage as a screw stops it from being taken out or moved.
Here's a guide on how to replace the hard drive if it is faulty:
Remplacement du disque dur de la PlayStation 3
You can buy the hard drive from here:
500 GB 5400 RPM 2.5" Hard Drive
Or literally any 2.5" hard drive or SSD will work as well. Just make sure it's at least 120GB or more. You will most likely need to download system software when installing a new hard drive.
Man thank you....
Dernières 24 heures : 17
7 derniers jours : 208
30 derniers jours : 826
Total : 51,496
6 commentaires
I had this problem as well. My ps3 has gotten knocked off the shelf and as a result I got the same fault. As it turned out the hard drive was not fully seated and it wasn’t connected. I pushed it in about 1/8” and system is normal.
par Dennis Lee
Thhaannnkk u!!! I was sad and thinking like am I gonna have to buy a new game and I'm only 13 and I have currently 4 dollars in my wallet. MAY GOD BLESS YOU. And I'm talking about Dennis Lee
par Jordan Smith
You’re very welcome
par Dennis Lee
I just got in my replacement hardrive but it didn't make that error go away. Is my PS3 just dead?
par contact
contact. I have the same problem. Did you fix the problem you had and if you did what did you do?
par Kooper King
Afficher 1 commentaire en plus
