Aller au contenu principal
Version revisitée de l'iPhone 3G avec une vitesse de traitement plus élevée. La réparation de ce modèle est similaire à celle du 3G et nécessite de simples tournevis et outils pour faire levier. Modèle A1303 / capacité de 16 ou 32 Go / coque en plastique noir ou blanc.
20 questions Voir tout
Lock Button Not Responsive
So a few days ago, the lock button on my friend's iPhone 3GS stopped responding. When pressed, it does nothing. This makes using it quite annoying. Acording to her, it just happened out of the blue, and wasn't caused by anything. Anyone know what i should do to fix this?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
6 Réponses
Solution retenue
This is pretty common amoung iPhone 3G and 3GS's and is due to the supportive brackets inside the phone being made of plastic and wearing out over time. Eventually they get so weak that when you press the button the whole assembly shifts down instead of just the button.
This happened in my old iPhone 3G and I was able to get some additional life out of it by squeezing the phone right below the button to hold the assembly in place, but eventually that wouldn't even help. I had to replace the Headphone Jack Assembly which contains the power button.
Image Replace a dirty or corroded headphone jack, or a damaged internal audio or power button switch.
Produit
iPhone 3G/3GS Headphone Jack Assembly
$14.99
Indice 3
I had the same problem. In my case, the button itself was defect, because there was dust between the electric contacts. I disassembled it, opened the button (removed the tape with that metal disc), cleaned it with q-tips and replaced the tape.
Works fine now ;)
Indice 2
How can I know, which part exactly is defect?
On my 3GS it feels like the Lock-Button has moved a little bit inside the phone and doesn't stand out as usual..
Indice 0
Trial and error really, if cleaning the contact point and re-assembling doesn't work then you'll be looking at replacing.
Indice 0
i forget my phone password
Indice 0
1 commentaire:
how to do this
par
i got the same problem with i phone 3gs 16 gb , lock button not working when i was cut the phone call it immediately got locked most of the time, any solution, shall i go to apple store to repair the phone.
Indice 0
Ajouter une réponse
Chris Green sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 13
Total : 48,035
