Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La manette sans fil Xbox One modèle 1698 a été lancée par Microsoft en 2015 aux côtés de la manette modèle 1697. Cette manette est similaire au modèle 1697 avec des modifications internes. Elle a plus de fonctionnalités qu'une manette de base, tels que des joysticks amovibles et des boutons D-Pad en métal. La manette est principalement conçue pour une utilisation en console, mais est compatible PC.
Why my Rs (right stick) button is not working
My right stick stopped functioning for some reason on my xbox one, and even xbox doesnt even know hoe to fix the $@$*, for some sort of reason my elite controllers right stick appears to be un mapped at all settings, and it doesnt work at all when playing games
Répondre à cette question J'ai le même problème
Indice 2
6 commentaires
I have just run into this issue - and so far been unable to find a solution.
I know it is the xbox — not the controller — as the right toggle works when I run the test mode in accessories, and because the same thing is happening to both controllers.
It isn’t the magnifier, and I’ve done a restart (with xbox unplugged for 5 minutes) 3 times.
Next, I’m resetting the xbox. Will update.
par
Having the exact same issue. Right joystick works in test mode and when I have the magnifier on. At no other time does it work though
par
Same mine doesn’t work either for some random reason and it’s frustrating because for some games that button is a crucial part of your controller but, I can’t use it I’ve tried using Xbox’s method of reseting and unplugging or whatever it said but that unfortunately did not help at all. Hopefully I’m not alone and this is just a bug with the connection of frequencies because the last few comments have been in a very close time period. This is really frustrating considering that my left joystick is already drifting so now the fact that I can’t use my right joystick (besides looking around). Idk what to do at this point and my controller costs around 140$ so right when it stopped working I was scared that my controller was breaking even more but it doesn’t seem like that considering that it works to an extent I’m gonna contact Xbox support and post what I find out and see if they have any tips.
par
Reading through these posts and I’m dealing with the exact same issue and have followed the steps. Anybody got in contact with Xbox support yet or should i waste my time?
par
Hey not sure if this will be helpful for everyone but there was a bug in CoD Vanguard that caused the input to be switched to mouse and keyboard. If you go back and play the game you were playing when the stick stopped working and press the D-Pad it will recognize it as a controller. Not sure if this bug is game specific but just another possible fix in this frustrating situation
par
Afficher 1 commentaire en plus
Ajouter un commentaire
3 Réponses
Réponse la plus utile
I had the same issue and after further investigation I found out I had accidentally turned on the xbox magnifier setting at some point (lol). To fix the issue:
1. Hold the xbox button until the menu pops up asking you to either turn off the console or the controller.
2. Press the back button to turn off the "Magnifier" setting.
3. Try your game again.
4. Enjoy!
Indice 9
9 commentaires:
Wow I glad you posted this I canf believe I thought it was my remote . But you were right it the magnifier was on
par
Thank you so much but my screen @rxs127 but why want my screen zoomed in
par
Thank you so much , I was going nutz trying to figure out what happened to my controller.
par
Thank god thougjt controller was &&^&@@
par
I feel dumb lol
par
Voir 4 commentaires en plus
I had same problem I used magnifier to zoom in an forgot to turn it off thought right thumb stick was broken tried another controller so thought it was game then realized it was on so turned off magnifier zoom holding Xbox button in middle of controller then hit back or select button an then it worked fine hope this helps
Indice 1
There is a chance the button has gone bad, If you have followed the steps for disabling Why my Rs (right stick) button is not working by Rxs127 and nothing works still, then you might want to look at Changement potentiomètre du joystick manette Xbox One Elite (modèle 1698) which will replace the joystick and the button. It is possible to replace just the button but you’d need to find the specific button to replace it with.
Indice 0
Ajouter une réponse
asureshot96 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 14
30 derniers jours : 125
Total : 42,302
