Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Mis sur le marché en juin 2009 / Avec processeur Core 2 Duo cadencé à 2,66, 2,8 ou 3,06 GHz
The back panel of the display is coming off
The back casing of the MBP is coming off and I have currently secured it with tape, but I am not sure on how to get a permanent fix.
It looks like this:
I am totally unaware of what to do. The apple store has said the machine is vintage and are refusing to fix it. I have spoken to a 3rd party apple repair specialists requesting anywhere from $439 to $1349. I do not want to but a new one. All I want is a permanent fix for the issue.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
2 commentaires
Does the display still work? Where do you live? With those kind of prices, I would guess Manhattan. Are those prices in US Dollars. I've done this repair several times. It's a fault in the frame (it breaks) about an inch up from the bottom of the display. It's a design flaw. Repair involves both repairing the frame and epoxy building up the support. But I have not had one fail after repair.
par
how do you go about repairing the actually frame at that failure point?
par
Ajouter un commentaire
3 Réponses
Solution retenue
You came to the best place to get your system fixed! We'll help you though this.
First, are you up to doing this your self?
Review this IFIXIT guide on what it will take to open your system and take the lid assembly off: MacBook Pro 15" Unibody Mid 2009 LCD Replacement. Here we need to get to the back side of the case (behind the LCD) as I suspect the screws which hold the mid frame have either loosened up or striped the holes. If stripped you can use some foaming urethane glue to glue the mid frame to the cover. Here's an image of the area so you can see what I'm talking about: Inside Lid Assembly. Note the large black head screws.
The other option here is to replace the complete assembly. You should be able to buy a used unit.
Indice 2
I wouldn’t trust repair shops that want you to spend over 1000 dollars on a machine that is bound to break down at any moment. It’s just not worth it. If you want to spend that much, I recommend getting a way better machine that is supported through software. I recommend a 2015 MacBook Pro as it still has the traditional ports
Indice 0
For Pete's sake, don't get rid of it. It's all about nostalgia! I just used a bootleg update and now run Mac OS Catalina on my MacBook Pro 15" Unibody Mid 2009 and it works great. I just had the same thing happen and plan on repairing the screw holes any way I can. Apple's are the pinnacle of computers and last forever. I hated the fact that they forced its software obsolescence - But I found the workaround :-).
Fix it and keep that awesome MacBook
Indice 0
Ajouter une réponse
Rishi raj sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 38
Total : 1,331
