Hi @Titus Bohanan,
Here’s a link to a service manual in which it details how to test the cooling system components, e.g. temp sender unit, fans etc.
I realize that it is not for your exact year model (it is for a 1998 -2002, couldn’t find it for your year model) but hopefully it will still be of some use.
See p.10-19 for the troubleshooting section regarding your problem with the radiator fans
According to the manual there is a radiator fan switch A and a radiator fan switch B and it suggests to check the circuit for radiator fan switch A when the symptoms are what you have, i.e. both fans (radiator and condenser) do not run for engine cooling, but they do run with the A/C on.
See p.10-7 for the coolant temp sender testing procedure to check if the sender unit is OK.
You will need a DMM (digital multimeter) as there is need for a Voltmeter and an Ohmmeter to perform the tests. Adequate DMMs are available from larger hardware stores for about $15-20. If you don’t know how to use a DMM get one that comes with a good user guide (some are woeful) so that it will be easier for you to understand and use. If you already know how to use a DMM, apologies.
To make reading the service manual easier, download the file to your computer. The download link is at the bottom of the Document page just to the right of where it says Zoom 100%
A voté
Annuler
Indice
2
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
5 commentaires
Hi, Have you checked the coolant level in the coolant reservoir?
par jayeff
Yes, coolant level is fine! The temp. gauge goes to red hot or pinned as soon as I start the car cold. And...after approx. 15 min. driving locally, the engine doesn't seem to be overheated. so I'm assuming that the thermostat is working fine. I'm just afraid to drive it longer or farther when the temp. gauge says red hot.
par James
I’m having the same issue with my 97 CL 3.0. Replaced the timing belt, crank shaft and cam shaft sensors, thermostat, engine coolant sensor and it’s still pegging hot after a few short minutes of it running. I have not checked the sensor with an ohm tester as I do not have one (which I know I need to get one). Do any of you suggest me purchasing the ECU sensor as well? Also, the fan isn’t turning on after the engine gets hot. Both fans will turn on when I turn the AC on. I’m kind of at a loss at the moment. Please help! Lol
par Titus Bohanan
Replace gauge sensor temperature, it´s cheeper, it´s worth.
par Laercio Civali
The radiator was clogged. One fan blew hot air, the other cold. Cleaned radiator, problem solved.
par Laercio Civali
