Weird screen issue - anyone seen this before?
So about 2 months after I replaced the iPhone 6 plus LCD this happened!
http://oi66.tinypic.com/5v92j5.jpg
It is static. The touch seems to respond as I can blindly hold the power button and slide to turn off but the image doesn't change!
Anyone encountered this before please help!
BTW I tried reconnecting the flex cables, looked for any signs of damage but found none.
par jackchangpoker
Did you disconnect the battery connector and reconnect, then do a hard reset?
par Gigabit87898
Yeah sometimes it's the screen or a nand flash memory issue (not enough space / overfilled / corrupted / damaged).
par Ben
The problem is that when I connect another screen then the phone works fine.
And when i connect this bad screen to another phone it has the same issue.
So the issue must be with this screen...
par jackchangpoker
