Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La manette sans fil Xbox One modèle 1697 est sortie en 2015 et a remplacé la manette modèle 1537 et a corrigé certains des problèmes trouvés sur ces modèles. La manette modèle 1697 comprend une prise casque intégrée de 3,5 mm, qui la rend compatible avec la plupart des casques tiers sans avoir besoin d'un adaptateur. Cette manette a été abandonnée et remplacée par le modèle 1708.
Is there a fix for directional "wandering" on Xbox one controllers?
On all three of my XB1 controllers the arrow, reticle, or avatar will move or wander on its own even when not touching thumbsticks: IS THERE A FIX FOR THIS?? or is this how MS gets an extra $70 out of each Xbox owner every few months? ANYONE??
Répondu ! Afficher la réponse J'ai le même problème
Indice 10
4 commentaires
its fairly easy to fix you need to replace the entire stick mechanism inside the controller itself. I just did this job myself, follow the guide for tear down and simply de-solder all 14 points push out from the bottom insert the new mechanism and resolder the devices pins back to the board.
par
You don’t have to take all the points off just find out which one is bad and just take the three points off and then replace that part the green part snap on and off really easy
par
is there not a hard reset like the good old controllers???
par
How do you plan to "reset" a hardware issue?
par
Ajouter un commentaire
3 Réponses
Solution retenue
If your Xbox One Wireless Controller has a malfunctioning thumbstick and you cannot properly navigate around your Xbox One, see the Xbox One Wireless Controller Has Malfunctioning Thumbsticks problem page for possible problems and solutions.
Indice 2
3 commentaires:
they always seem to start that wander around 4-mos or so "surprise" warranty is 3mos ,btw have you heard of "levity"or do you owe MS something?b'cuz I sure don't,but thanx for nothing tom
par
Interesting. Xbox One controllers are warranted for 1 year here. If you do want to fix it you have to replace the joystick module, which should be available on Alibaba or somewhere. Disassembly and soldering required.
par
Well...u can take the controller apart, super clean the analong bases...rubbing alchohol works....clean teh crap out of it...fixed mine.....
par
Réponse la plus utile
yes you can fix it but you have to be willing to strip down the controller, on a part of the joystick there is a place for a little flat head screwdriver, you have to turn it slightly for it to change the vertical or horizontal scrolling.
Indice 4
Yes. It's just a cleaning issue.
Indice 0
Ajouter une réponse
voodoo24u sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 32
Total : 27,148
