Tear-down of new 2017 iMac 5k
Why not do a disassembly of new 5k 2017 model?
These questions are very important to me:
- The HDD is upgradable without needing a thermal sensor?
- Is the CPU upgradable?
- Number phases CPU? GPU?
- Model number memory GPU ?
Can I update my CPU i5 3.8 (7600k) with i7 4,2 (7700k), the phase corresponding in watt?
Thank you in advance.
5 commentaires
Does the 27" 5k 2027 SSD only model still have the HDD brackets installed, asked at Apple store but not much luck with an answer, they didn't seem to realise you could get a SDD only model.
par John
John - Good question!
We'll need to wait till someone opens up a SSD only model. The OWC vid below is a Fusion Drive config so it had the drive. Even still, the brackets are the standard ones the 'Thin Series' uses so you can get them and remember, you'll still need to get the custom SATA cable anyways to add the drive.
par Dan
Just notice this on You Tube, I think this will answer a lot questions about upgrading a 27"5k 2017 iMac The Best 2017 iMac Apple Doesn't Sell!
par John
Can you add to this mac an SSD like in the above videos, but also still keep and HDD inside? So for example a 512SSD and 2TB HDD configuration.
par Andrei Birsan
Andrei, your system supports two drives one SATA (HDD or SSD) and one Custom PCIe Blade Drive (SSD only)
par Ben
