Aller au contenu principal
L'Apple iPhone 5s fut annoncé le 10 septembre 2013. La réparation de ce modèle est très similaire aux modèles précédents et requiert des tournevis ainsi que des outils pour faire levier. Disponible en version GSM ou CDMA, 16/32/64 Go de stockage et en argent, doré ou gris sidéral.
3530 questions Voir tout
My iPhone 5s home button does not click.
I bought this phone used and didn't notice initially that the home button doesn't make a clicking sound like its supposed to. I've tried cleaning with alcohol but it didn't improve much. Functionality is good if I push hard with my thumb nail, but that's awkward. Could something just need tightening?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
In my experience, simply loosening the screws a quarter turn will suffice. It all depends on the screen that's being used tough, since you bought it used you'll have to open up and see if the screen is original or not.
I have experience with really crappy screens that either sit too tight like in your case or too loose to be pushed beneath the screen.
Ben's answer is a good solution to it is as well in the case of a crappy screen, but try loosening the screws a bit before you go bending the plates!
Indice 1
1 commentaire:
Thanks! It didn't restore the full click but it improved the functionality a lot
par
Réponse la plus utile
You need to either bend the metal plate that holds in with two screws behind the home button either inwards or outwards from the center.
That way you can adjust the distance between the metal plate circle and the home button.
Indice 3
Ajouter une réponse
Melissa Taylor sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 121
