Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,4 GHz, 2,7 GHz ou 2,8 GHz (Turbo Boost jusqu'à 3,8 GHz) avec 6 Mo de cache L3 partagé.
20 questions Voir tout
After iFixit battery replacement, machine does not boot
Hello, I purchased the iFixit 15" battery replacement kit to replace the awful OEM battery inside my MacBook Pro. After replacement, the machine does not boot or chime. I tried an SMC reset but it did not respond. It does not respond to a long press of the power button either. The fans spin up after I plug in the charger, but if just the battery is connected, nothing happens when I press the power button.
I plugged in the original battery and that allowed it to boot.
What is wrong with my new battery? Thanks!
Répondre à cette question J'ai le même problème
Indice 0
3 commentaires
Lets not throw dispersions at Apple. The batteries they used are not that bad.
par
Dan, of course not, I meant that the battery had a bad cell and was dying spontaneously below 50%.
par
As they say there's always a bad apple in the bushel. Sorry yours gave you a hard time.
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
You'll likely need to charge it for a while. What color is your MagSafe charger LED Green or Amber?
Indice 2
6 commentaires:
Dan, I will try that. I found an 85W adaptor (forgot I was using a 60W) and got it to power on. However, CoconutBattery reports that the battery is not charging at all.
par
Give it a good 24hrs then you'll want to do a SMC reset, let the system run down the battery until it won't boot and charge it again for a good 24hrs this will calibrate your battery. And yes you do need the 85W charger ;-}
Here's a good writeup: Calibrating Your MacBook, Air, or Pro Battery
par
Sounds good! I'll report back after a day.
par
Okay--I left it on the charger for 24 hours. Nothing changed. Percentage didn't rise. The battery status is still 'poor' in CoconutBattery. I can't unplug or use my laptop--it just shuts off. I think I've received a bad battery.
par
Was the old battery charging at all?
par
Afficher 1 commentaire en plus
Have you checked to see that all the pins are lining up when you plug in the new battery?
Indice 1
2 commentaires:
Yes--It can only really go one way.
par
Sorry, I should rephrase that. Are there any bent pins on the battery connector or the plug itself?
par
Ajouter une réponse
Keaton Burleson sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 194
