iPhone 3GS no power
Hi all! I got 2 iphone 3gses that do absolutely nothing when connected to power and nothing when connected to itunes. Completely dead. Need help ASAP! Phone has never been dropped or got wet.
@e_ah start with new batteries and make sure you get the right ones. This series iPhone is very finicky about the battery. After that check the dock connector and make sure that it is clean, has not broken or bend contacts. Clean it out with a few drops of 90%+ isopropyl alcohol and a few puffs of compressed air. Then you need to do some measuring. When you plug it in measure the voltage on the battery connector. Should be no less than 3.6V you can also check a few of the "fuses" for continuity.
Number one thing to do, replace the batteries! This is really important since that will give you a known-good starting point should further troubleshooting be needed.
I have just tried the solution and the fuse is blown. Since the phone is only worth 10$ ima just recycle it Thx for the wander tho
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 6
Total : 194
