Aller au contenu principal
Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
20 questions Voir tout
upgrade ram mac mini server (mid 2011)
ho un mac mini server (mid 2011) con 8gb di ram, è possibile aumentarla a 16gb? se si quale è la migliore?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
I have a mac mini server (mid 2011) with 8gb of ram, you can increase it to 16gb? if which one is the best?
par
Ajouter un commentaire
1 Réponse
Solution retenue
Standard RAM: 4 GB Maximum RAM: 16 GB*
Details: By default, 4 GB is installed as two 2 GB modules.
*Officially, this model supports 8 GB of RAM, but as first discovered by OWC, it actually is capable of supporting 16 GB of RAM using two 8 GB modules.
RAM Type: PC3-10600 DDR3 Min. RAM Speed: 1333 MHz
Installation de RAM dans le Mac mini (mi-2011)
Indice 4
4 commentaires:
hi, the ram for mac mini mid 2011, can we use 1600 PC3-12800 - does it need to be low voltage model ?
par
This model uses:
Details: Supports 1333 MHz PC3-10600 DDR3 SO-DIMMs.
par
noted on that, but do we have to use DDR3L or normal DDR3 ? thanks
par
Either will work!
The L is for low voltage option. This RAM will work in either normal or low voltage systems.
par
Ajouter une réponse
massimo mignogna sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 919
