Aller au contenu principal
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
Questions au sujet de 289 Voir tout
What fuse is for the Cigarette lighter
What fuse is for the cig lighter
Répondre à cette question J'ai le même problème
Indice 3
4 commentaires
@michmadman6969 what exact year is your Pickup
par
Its a 1991 chevrolet gmt 400I
par
2005 dodge caravan i need to know wut kind of fues do i get for the car lighter
par
88 chevy s10 pick up the cig light doesnt work what and where do i change the fuse
par
Ajouter un commentaire
3 Réponses
Réponse la plus utile
@michmadman6969 should be part of the Convenience Center (fuse box interior left side of dash). According to the wiring manual for your model it is marked as CTSY
Indice 5
10 amp fuse, this will be found if you check the fuse in the cab not under hood and check for sure and read the diagram to check which to pull out and if you cant read google that $@$* too
Indice 1
2 commentaires:
It's a 10 Amp, I have a 20 Amp in mine. And there should be another Fuse panel, when you open the drivers side dash board a little panel which got me too, all your other fuses are there.
Found out the Hard way $$$$
par
15amp fuses should work. If It does not, look on the side.
par
Hello John,
The fuse is usually labelled as Cigarette Lighter, The fuse number cannot be given as you did not include a Year or model # in your question. The fuse block is usually located inside the cab on the drivers side however.
Good Luck,
Rich Lilja
Indice 0
1 commentaire:
Its a 1991 chevrolet gmt 400I. It isn't marked in the fuse panel. Was told the radio fuse but the radio works fine
par
Ajouter une réponse
John Ladd sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 87
30 derniers jours : 393
Total : 16,935
