Aller au contenu principal
Sorti 22 septembre 2017. Modèles A1864, A1897. Disponible en version GSM ou CDMA / 64 ou 356 Go / Or, argent et gris sidéral.
20 questions Voir tout
Touch not working after repair (PSA)
I use very high quality aftermarket parts from a supplier who backs them with a lifetime warranty. The 3d functions almost identical and the color and brightness are almost spot on to OEM. The main reason I use these is because most customers care about cost and nothing more. Atleast, that is my experience ( I fix around 40 phones a month for extra income). Overall, I have very little issues with their screens. I said all that to say this/ask a question.
Today, I attempted to repair an iPhone 8 plus. I have fixed two recently with no problems. After testing the screen before snapping it in, all was well. After installing it all the way the touch functioned fine, but after I locked and unlocked the phone, the touch died. I tried reseating cables, pulling the screen out to sit on cardboard incase of grounding out etc. Nothing worked. I tried another 8 plus screen from a different supplier. This time the touch never worked. I started to panic, because I believed I had blown a fuse or cap that controls the touch. I tested the broken original screen and it worked fine. I tried two more screens with similar results to the first attempt. It worked fine, but after locking and unlocking the phone the touch wouldn't work.
I gave up, since I was out of screens and gave the phone back broken, but working.
Now here's what worries me. I noticed the phone was updated to iOS 11.3 yesterday. I just successfully repaired an iPhone 8 plus yesterday from the same batch of screens. I confirmed with the customer that she had not updated to iOS 11.3. What are the chances that I had 4 bad screens exhibit the same behavior from two suppliers? Im hoping this isn't a glitch in iOS 11.3 and if it is, will it affect screens across all models? Yes, I know it's best to choose original repair parts or at least original refurbished parts, but customers don't want to pay 50 to 60 bucks more on average for a repair even after I explain the differences.
Répondu ! Afficher la réponse J'ai le même problème
Indice 4
Ajouter un commentaire
8 Réponses
Solution retenue
FYI. We buy some parts from this vendor, but not iPhone screens. However this is probably what you are looking for.....
Indice 2
5 commentaires:
Great find. Thanks.
par
I predict 11.3.1 will be released soon.
par
I’m having this issue now just had my iPhone 8 Plus screen replaced but now it glitches I can’t type freezes every few seconds everywhere
par
I am in South Africa and really struggling the cost is just too much please help me
par
@Chipo Mboshi Nobody can help you at a distance if you have a display hardware problem. If you did the replacement yourself, try reseating the connector on the logic board, it should fit in with a light clicking sound. If you got the screen replaced by a third party, best thing to do is to get back where the job was done.
par
Honestly hard to tell because I haven't gotten clients wanting to repair iPhone 8 yet.
I've only tried one iPhone 8 screen and closed it touch appeared to still work but this was only for data recovery purposes.
Guessing you've done heaps of iPhone 7 and 7 plus right? Pretty much same procedure to that one.
Indice 1
3 commentaires:
Yes, I've done a lot of 7 and 7 plus screens. It's very strange. I hoping it's not iOS that's the problem.
par
I think the signing servers are still active for 11.2.6.
Why don't you download the full firmware for 11.2.6 and see if the phone works properly if you downgrade. Better work quick while they are still signing.
par
Yeah 11.3 and 11.2.6 are currently still being signed by apple servers at this moment.
par
so this is a issue with the new ios, downgrading it will make a aftermarket screen work. guess its going to mean finding a screen disto that has premium quality screens or waiting to see if they make a patch for it.
Indice 0
I had my iPhone 8+ screen replaced a while ago, which resulted in a lack of audio from earpiece. After getting that replaced, phone was just fine. Now, I just installed a software upgrade (whatever newest one is. 11.3?) and no touch response whatsoever even with umpteen hard resets. Can't reset through iTunes because the passcode is activated and I can't enter it. What can I do? I have no idea how to revert to my old iOS and I have no idea what's going on. Do I have to go to Apple or can the guy who replaced the screen initially fix this for me? Also, I know you have to turn Find my iPhone off for them to provide support, but I can't even do that! Help! I NEED my phone.
Indice 0
1 commentaire:
Get the person who fixed your phone to downgrade iOS or install an original apple screen. The later may cost you, because the cost of an original screen usually averages $90.
par
After IOS 12 upgrade the screen on my iphone 7plus was completely frozen. Resetting phone a number of times produced zero results. The only thing that worked for me was to put the phone into DFU mode (Hold power and Volume down button simultaneously untill DFU mode is entered). Then plug phone into Itunes and click restore button but only allow restore process to continue for a few seconds. shut down itunes, unplug cable to phone and hold power and volume button until logo appears. Phone should now work.
Indice 0
Is this still an issue for replacing the screen on the iPhone 8/8+? Or have the more recent ios updates fixed this issue.
Indice 0
3 commentaires:
This has been fixed since one of the iOS 11 updates.
par
I’m having this issue now just had my iPhone 8 screen fixed for the second time and now suddenly after two days it stopped working not sure which version I currently have on my phone but think I’m missing one maybe more updates.. on holiday so don’t have my computer current.. help what do I do..?
par
Shar you need an original Apple screen.
par
Hi Guys,
I am still experiencing this problem rn. I did a repair on the phone for my friend who has a iphone 8 plus, the touch is not working after the repair, im not sure what the problem is as of now. i cant even go on itunes as the phone has a passcode on it. please advise me on what to do.
Indice 0
4 commentaires:
Is the broken screen still useable? If so, can you put it back on as a test to see if the touch is still working?
par
You have to get Apple to replace it with their own parts. I had a place fix my screen but then an update happened and the screen was not compatible with the new software. Only Apple screen replacement fixed the problem. Unfortunately, getting a third party to fix it voids warranty.
par
Did they just charge you out of pocket cost for the repair or would they not even touch it thanks to the third party initial repair? @c_lag
par
Apple took care of it but charged me the price of a full screen repair. So I had to pay for two screen repairs basically
par
For iPhone 8+, changing the screen will probably result in having the touch not working. But if you install the screen with disconnecting the fingerprint it’ll work. Try that!
Indice 0
Ajouter une réponse
Brian Wood sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 9
Total : 19,190
