Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The JBL Charge 3 can be recognized by its distinct woven speaker cover and rubber accents. It was released in 2016 and features a fully waterproof design, 20 hours of playback time, and bluetooth connectivity.
Charge 3 and Flip 4 will not connect in Stereo only Party Mode
I upgraded the Charge 3 to the Connect+ firmware. I have connected the Flip 4 and the Charge 3 together and both work fine in Party Mode. Once I try to select Stereo it throws and error saying to move my phone closer and try again and close the app etc. I have done all that. Turned the speakers on and off. Repaired Bluetooth. Uninstalled and reinstalled the app, but only seems like party mode works. Please help
Répondre à cette question J'ai le même problème
Indice 3
Ajouter un commentaire
6 Réponses
Stereo mode requires two of the same model speakers.
Indice 0
6 commentaires:
I have two of the same models flip 4 and its not working. Only while testing it in the jbl connect app it works. But once I close the app and play music it default back to party mode. Stereo is only native and the same on both speakers.
par
Me, too. Even I'd succeed to connect the Stereo mode, but just few seconds later, the mode has been changed by itself to the Party mode. It doesn't keep in the Stereo mode. The Stereo mode is in activity under the JBL Connect + App. and to check test Left and right channel. When I get out from the App, then it switchs to the Party mode. I'm having this test with two Flip 4s.
par
I have two JBL Charge 3, and only work in Party mode, after the latest Firmware Upgrade. Before it's workings perfectly.
par
Connect only 1. Box with Handy. Start 2.Box and Press the connect Butten. So you can go to the Stereo Mode.
par
Man you are a lifesaver, thank you. Couldn’t get stereo to work, but following your instruction worked. Connect only one speaker. Turn it on. Then turn on one that is not connected to phone and press Jbl connect button on it. And after it press Jbl connect button on speaker connected to phone. Do not quit app while doing so, switch to stereo and don’t open app again. It will not work but speakers will stay stereo
par
Afficher 1 commentaire en plus
How do you put a charge three and flip 4 in party mode?
Indice 0
1 commentaire:
Connect only 1. Box with Handy. Start 2.Box and Press the connect Butten. So the Box go to the Party Mode.
par
My two Charge 4s seem to work normally with JBL Connect except that the output is not really stereo even if stereo mode is chosen. Also swapping he channels does not work. Both have the latest firmware 3.0.0.
Indice 0
3 commentaires:
Tried older (8/2019) JBL Connect. Doesn't help.
par
I have also booted the phone (LG G6) and factory reset both speakers.
par
par
I checked the way to connect as stereo. Only one speaker should be paired with the system. Other should not be. Being only one speaker paird with the audio system. Connect the unpaired speaker with paired using the connect button in the speaker. Then the stereo and party mode works fine in the jbl connect app. Remember only one speaker should be paired with the audio system.
Indice 0
While using two JBL speakers (FLIP 4) in stereo mode, JBL connect will automatically go to party mode if the music is paused for 5 sec. This is so annoying as app shows it is in stereo mode but actually it will be in party mode. You have to again switch from party mode and again to stereo mode. If the music is paused we have to do it again.
Indice 0
1 commentaire:
Niraj Shakya
It happens to me in the middle of songs all the time. It switches to party mode on its own all-the-time--<every> time i use it, and it's super annoying. I'm gonna have to try the previous suggestions of pairing just 1 of the Flips and see if that makes a difference.
par
Unlike Bose, with JBL you gotta have two of the same speaker with same model inorder to play them in stereo
Indice 0
Ajouter une réponse
Brian D Anderson sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 37
Total : 18,029
