Aller au contenu principal
Comment réparer son MacBook Pro 13" Unibody, modèle mi-2012, A1278, processeur 2,5 GHz i5 ou 2,9 GHz i7.
1624 questions Voir tout
No Display and no backlight but external display works
i have a macbook pro 2012 that is showing no image on the screen with no backilight and if an external monitor is connected and i go to about this mac > Display it doesnt show up to the system
Please help i need to fix it asap
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Sounds like you have some liquid damage to the logic board at the location where the internal display is connected. You’ll need to open the system up to inspect the connections for damage. Follow this IFIXIT guide to Step 4 Remplacement de la carte mère du MacBook Pro 13" Unibody mi-2012. Then jump down to Step 15. Does your connector and the solder joints look like this:
If not you’ll need to do some cleaning and you still may need the logic board repaired or replaced (as well as the LVDS cable to the display).
Indice 1
4 commentaires:
to my knolege the device has never been in contact with liquid
par
You'll still need to open the system to check things out. Take a few pictures and post them here for us to see Ajout d'images à une question existante
par
Agreed possible liquid damage to the connector.
par
i will attempt to take pictures tomorow, had the mac appart and completly removed the display assembily to tighten hinges but theres still no life after putting everything back
par
Ajouter une réponse
Delete This sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 1
Total : 53
