Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to remotley disable FRP lock?
I have recently flashed a custom recovery on this phone. Since I forgot to disable frp lock (Re-enabled it by setting up phone after flash) it will be blocked from entering the recovery mode. for some reason it will boot-loop non stop. It will try to load the recovery then crash reboot and repeat. Thanks!
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
You need to put the phone back into download mode via holding volume down + power + home constantly and reflash the firmware or stock recovery file onto the phone.
How to flash firmware if you need it, flash with home_csc and not the non-home csc to avoid factory resetting the phone if needed:
http://updato.com/how-to/how-to-install-...
When you get phone working again go to settings, about phone, software info tap build number 7 times then go developer option and enable OEM unlock.
Indice 3
Ajouter une réponse
Ethan Leroux sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 21
Total : 5,095
