Trackpad not clicking after some use
The trackpad on my MacBook Pro (13”, 2017, No Touchbar) refuses to register clicks after 30 mins - 1 hour of use. Sometimes I have to press really hard for it to register, and often, as I hold (not press) my finger on the trackpad, it registers as constant clicking.
The MacBook had water spilt on it and the top case was replaced.
4 commentaires
a mi me pasa lo mismo ya lo he probado todo lo ultimo reinstalar el ma os y nada la unica forma que hay de que me vuelva a funcionar es la de dejar el mac apagado durante unos minutos, entonces funciona unos miutos y va perdiendo el click poco a poco hasta que deja funcionar la solucion tambien seria remplazar el trackpad?
The same thing happens to me, I have already tried everything last, reinstall the maos and nothing, the only way to make it work again is to leave the mac off for a few minutes, then it works a few minutes and it loses the click little by little until it stops working, would the solution also be to replace the trackpad?
par Oriol Tinez
@Oriol Tinez - Lo siento, sí, también necesitas una nueva unidad de trackpad.
Sorry yes, you also need a new trackpad unit
par Dan
okey gracias, pero es original no? porque ya compre un trackpad de otro fabricante olive me parece y me dejo de funcionar hasta el teclado conectandolo y no funcionava el trackpad tuve que volver a poner el antiguo
OK, thanks, but it's original isn't it? Because I already bought a trackpad from another manufacturer Olive I think and it stopped working until the keyboard connecting it and the trackpad did not work I had to put the old one back
par Oriol Tinez
@Oriol Tinez - Lamentablemente, debe utilizar la parte correcta de Apple [produit lié absent ou désactivé : IF123-057-3]
Sadly, you need to use the correct Apple part [produit lié absent ou désactivé : IF123-057-3]
par Dan
