Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La clé pour réparer et maîtriser vos poignées de porte, boutons et serrures.
How do I fix my door to lock
i can lock my door and the other side just by wiggling it will unlock it
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
You’ll need to replace the lock set as the button latch within the inside handle is worn or bent. Given this is an outside door you should get a deadbolt installed either within the same handle plate or independently.
The easiest way is to go to the local hardware store with a good set of pictures so you can get the same model. If you have the make and model that would be even better! You might find there is a second version with the dead bolt.
Adding the deadbolt is not overly hard if you have access to the needed tools.
Here’s a useful link: This Old House - All About Locks
Indice 0
Ajouter une réponse
Krista davis sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 37
Total : 1,149
