Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations de service et de réparation pour le Huawei Mate 8, sorti en novembre 2015. Il fonctionne sous Android OS v6.0 et arbore un écran de 6,0 pouces. En plus d'un capteur photographique principal de 16 MP et d'un capteur photographique secondaire de 8 MP, le Huawei Mate 8 est également doté d'une batterie Li-Po non amovible de 4000 mAh.
Does changing the battery also require us to change the screen?
I've been having battey charge drop problems. When I go to the Huawei service center they tell me that battery change will also require a screen change. (Without even checking my phone). They say that the battery comes with the screen. My screen is in perfect condition. Is it true that the battery change will also require a screen change?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
3 Réponses
Solution retenue
@slot1gamer @jayeff Thank you guys. It sounded silly to me as well when they said that the battery and screen both have to be replaced.
Indice 0
Réponse la plus utile
Hi @alieffendi ,
Looking at the Remplacement de la batterie du Huawei Mate 8 guide, it is not necessary to remove or replace the display.
If you decide to replace the battery yourself, read the comments at the bottom of the guide for a tip that may be of some help.
Indice 3
2 commentaires:
depending how you look at it, are you removing the screen or removing the back?? hmmmm
par
Hi @slot1gamer ,
Fair enough.
I've amended my answer.
Cheers
par
No they are being dumb..
The battery is stuck to the mid frame with some double sided tape, this is a job a day 1 tech can do.
Indice 1
Ajouter une réponse
Ali Effendi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 14
Total : 407
