@jwmurphyjr & @wonderman & @george72 - SATA specs do matter! Yes, it can be confusing!
George your system is only SATA II (3.0 Gb/s). The SATA spec is written to allow older drives to work in newer systems. Back then drives where fixed speed or had a jumper to set the I/O speed.
So to clarify a Fixed SATA III (6.0 gb/s) speed drive won't work properly in a SATA II (3.0 Gb/s) or SATA I (1.5 Gb/s) system. But! A Fixed SATA I or SATA II drive will work in a SATA III system.
The drive makers realized this was not what people where doing! Instead of re-using their older drives many people where upgrading their drives to larger units. Lets just say a lot of people where having issues back then.
To make things easier the drive makers stole auto sense technology from the Ethernet networking world. This tech allowed the drive to sense the I/O of the system and then dialing in on what it sensed! These newer Auto sense drives became the go to drives as they do in fact work in any system
So an Auto sense SATA III drive will dial back to SATA II to matching your SATA II system! All was well! And for many a year the issues with fitting drives into older systems,s was not an issue!
Now we do have a new problem as over the last few years to be price competitive many drive makers are dropping this auto sense circuitry! Don't forget olderSATA I and SATA II systems are mostly no longer being upgraded or even used! So the need for the Auto sense logic is just not needed as much.
Once again we need to be careful on what drive you use! Some drives are still auto sense and you do need to make sure you use one in your system or a fixed SATA II drive!
You need to review the spec sheets to figure out what the drive offers. Here's the two drives:
● Crucial MX500
● Samsung 860 EVO
You want to check the interface line looking in the spec sheet, to see if your systems SATA I/O speed is listed Auto Sense. If its not the drive most likely won't work reliably Fixed Speed. If it's not written I wound't trust what people tell you.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
1 commentaire
Your systems specs: MacBook Pro 13" 2.53 GHz Core 2 Duo (SD/FW)
par Dan
