Replacing drive and yellow connecting (1210) ruined when removing
Part to connect to drive cable 1210 yellow cable is not fitting worried i ruined it removing?
Note that there is a locking tab on the connector that needs to be up when you insert it, then is pushed down to lock it into position. See step #14 of this guide
Remplacement de la nappe du disque dur du MacBook Pro 13" Unibody mi-2012
Yep that cable connected to a white box separate fron the drive cable ..connects to it
Heres the pic of part needed
It wont post but u had it pointed out in answer above
Here's the needed part MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable (with bracket)
@danj, it's not on the cable but on the bracket. It's the IR sensor.
@mayer - To quick with the link - Fixed
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 69
1 commentaire
Can you post a few pics so we can see what you are talking about Ajout d'images à une question existante
par Dan
