Aller au contenu principal
Repair guides and support for gas and electric hot water tanks, boilers and household heat exchangers.
Questions au sujet de 29 Voir tout
Pressure relief valve leaking
I have a leaking pressure relief valve in a electric hot water heater.it heater has been drained and off for about 6 mts, when I filled it up and it got hot it started leaking, now that it’s cooled down it’s still leaking but slower. Do I just replace the valve or is something else causing it?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
I experience the same problem and I’'ve already changed the valve
par
Ajouter un commentaire
2 Réponses
Solution retenue
Hi @olliebob ,
Try replacing the pressure relief valve.
If the new valve also starts leaking then you may have a problem elsewhere especially if there is a regulator or backflow prevention device installed in the supply to the premises.
Indice 2
Some of them are really poorly made, are you convinced you got a good quality one? You can think it can't be the valve’s fault as it’s a new one, but there are a few that you can get roughly one day of use out of. I think one of my friends experienced something similar, I might be wrong with the info I give cause I don't have a lot of experience with this part, but I'll try anyway. So what I think he did was change the strainer with a Y one, so the pressure could be easier to release and that might stop said pressure from fissuring the valve. I can also indicate the site where he bought the strainer from https://anixusa.com/y-strainer cause he didn't have any problems with it and as I said, it's important to get quality components if you want to get any use out of them.
Indice 0
Ajouter une réponse
Jim sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 65
Total : 1,103
