Aller au contenu principal
The InFocus LP540 is a digital projector, which provides video and computer inputs. It has a XGA 1024x768 resolution. The repair requires screwdrivers and other useful tools.
Bulb comes on; no menu available
I have an older InFocus projector (bought in 2005?). Haven’t used in a decade. I turned it on, the bulb lights up and projects on the wall, but that’s it. I can’t get it to even display a menu, and when I connect it to my MacBook, nothing new is displayed, just the square block of light from the bulb. Any thoughts on resurrecting this old projector? Thanks!
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
I have exactly the same problem with an infocus LP130 that hasn't worked for 5 years. Are there any tests to do on the motherboard?
Could the DLP be HS?
par
Ajouter un commentaire
1 Réponse
Solution retenue
Hi,
Just verifying that there is no indications at all when using the projector’s keys or the remote control buttons to see if the projector is responding to any user inputs? Stupid thought but pressing “blank” on the remote doesn’t restore the projector so that the menus now work or that there is an image displayed when connected to a computer?
If there is no responses at all I’m wondering if it may be a firmware problem and hopefully not a hardware problem.
Here’s a link to the firmware update for the projector. (scroll do to the Downloads section). The download file incorporates a pdf document along with the firmware that explains how to update the firmware. Just trying to do this may give an indication whether the projector still has some life.
If there is no response at all when trying this perhaps it may be a hardware problem, i.e. a faulty motherboard. After 10 years of non-use, components may have deteriorated or have been affected by the environment where the projector was stored.
Here’s a link to the ifixit InFocus LP540 guide which should be of some help in gaining access to the internal components for an initial inspection.
I cannot find a service manual online for the projector, you may have better luck.
Indice 2
Ajouter une réponse
fiddler5000 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 8
Total : 553
