My laptop is not turning on
Ok so I left for this morning and left my laptop on hoping it would go to sleep it did now it’s not turning on
what do I do this laptop is just problem upon problem
p.s it was connected to monitor and was left on charge
I take it the computer won't boot up from a total shutdown and not just from sleep mode and nothing is displayed on your screen when attempting to boot up. (that point is not clear from the contents of your query) If that is the case then you need to either try a replacement charger or use a multimeter to check your current charger is working properly and also the battery voltage. You can try taking out the battery and seeing if the computer will boot from the charger itself.
par prop man
Don’t I have to remove the back panel and pull the battery out. Is it not put in the laptop with glue
par Waqas Choudhry
Hi,
Here's a link to the ifixit Changement batterie Acer Nitro 5 AN515-53-55G9 guide which may help.
par jayeff
