Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Variante uniquement Wi-Fi de la cinquième génération d'iPad, lancée en mars 2017. Disponible avec 32 ou 128 Go de stockage en option, écran Retina de 9,7" et processeur A9 de 64 bits.
iPad is disabled connect to itunes on MacOS Catalina
Hi, I have a ipad with error message “iPad is disabled connect to itunes” but itunes is no more available on MacOS Catalina !
Can somebody please help me to restore this ipad ?
Répondre à cette question J'ai le même problème
Indice 8
1 commentaire
No one has yet found an answer. Apple sure stuffed getting ipad back alive
par
Ajouter un commentaire
7 Réponses
Réponse la plus utile
Check this out, it is still possible to restore an iDevice on Mac OS Catalina:
https://www.imore.com/how-sync-your-ipho...
Indice 3
Hi, Thank you for your answers ;-)
I finally found the solution. iPad was managed by “apple configurator 2”, so I started the iPad in recovery mode and connect to “configurator 2”. Then click on “recovery”.
Best regards
Indice 2
1 commentaire:
Thank you so much! This did the trick. I downloaded the configurator and clicked around with update (I believe I had to restart the iPad once to get the process going). It installed a new operating system.
par
hey! did u find out?? im having the same problem rn and i don’t know what to do lol
Indice 0
This is the official article on how to fix what you’re experiencing:
https://support.apple.com/en-us/HT204306
Indice 0
1 commentaire:
it didn't work :(
par
You know what? I read an article about this exact same problem!
So here is it: iPad is disabled connect to iPad
Basically, you hook up your iPad with your mac, and you will see a notification telling you to restore the iPad.
If not, the easiest solution is to use Joyoshare iPad System Recovery to restore the iPad without data loss.
Indice 0
Resetting the ipad can be done using the Finder on Mac OS Catalina.
  1. turn off iPad and unplug from Mac
  2. start Finder
  3. press Home button
  4. plug iPad in while Home button is pressed
  5. iTunes logo will appear on the iPad
  6. iPad will appear in Finder
  7. a prompt to update or reset to factory settings will appear on the Finder.
  8. Follow on screen instructions to update or reset the iPad
This video demonstrates this process.
Indice 0
if you have a separate device like windows you can use iTunes from there, or upgrade to a newer version of mac os
Indice 0
Ajouter une réponse
Guy Lerou sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 24
Total : 8,593
