Aller au contenu principal
The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
What screwdriver do I need to open the battery panel? MacBook Air 2015
I spilled a little vinegar on my laptop days ago. I’ve just got the right screwdriver to open the back of it but I’ve discovered that I need two different screwdrivers to open the battery panel. Where can I get this in stores! Please help! Thank you. MacBook Air 2015
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Here’s the iFixit guide you need to follow: Changement batterie MacBook Air 11" début 2015
You need the following screw drivers:
Image Precision fixed blade screwdriver engineered by iFixit.
Produit
T5 Torx Screwdriver
$5.49
Image Compatible with the type 5IPR fasteners used on MacBook Air, MacBook Pro Retina Display laptops, and Toshiba drives. Precision fixed blade screwdriver engineered by iFixit.
Produit
P5 Pentalobe Screwdriver Retina MacBook Pro and Air
$5.99
Indice 2
3 commentaires:
My laptop isn’t turning on. Do you think the batteries are just the problem? Where do I get new ones?
par
Before you jump into getting a battery. How about doing some basic tests.
When you plug in your charger what color is the MagSafe plug Amber or Green?
If the charger is not lighting inspect the contacts for damage and clean the contacts if needed.
Is the charger the correct one for your system?
par
The charger lights up when I plug it in. It turns from green to amber. I don’t want to start my laptop again because it shortens it. When I start it it turns on and then shuts down real quick. I can’t believe it’s not working. When I spilled a minuscule of liquid on it and wiped it up right away. I don’t see any corrosion inside nor any liquid. I don’t know what’s the problem. If you could please help me thank you
par
Ajouter une réponse
aimee sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 22
30 derniers jours : 94
Total : 9,452
