Aller au contenu principal
Introduite en 2016 lors du lancement de la Xbox One S, la manette Xbox One ajoute le support Bluetooth pour Windows 10. C'est la manette grand public actuellement vendue par Microsoft. Elle rectifie un nombre de défauts de conception des manettes modèles 1537/1697 et elle est beaucoup plus fiable.
20 questions Voir tout
How to remove Trigger hinge
Hey there, I know how to replace the bumpers above the trigger. But I’m not too sure on how to really replace the trigger hinge. That’s the part I need to replace as I cracked/broke off a plastic piece.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
I’m making the assumption you’re talking about the LB/RB assembly based on the description, since it matches the part description the best. Super Glue doesn’t work - been there, done that. Don’t waste your time.
The LB/RB assembly has been a single part since the 1697/1698 (Elite Gen1) controllers, which is completely different from the 1537 (no integrated 3.5mm jack). While you can’t get the 1697 part to work in a 1708 and vice versa (not that you’d want to willingly use the flimsy 1697 version of the part), you can get it separate from the entire case, but you generally need to buy a part kit with the IR cover, sync button and trigger part because almost nobody sells it piecemeal - it’s also a good idea to replace all of those for cosmetic consistency and the fact removing the cover can stress the plastics, but it’s not a hard requirement. If you’re gentle, it will be reusable.
In order to change it, you will need to follow this guide and remove the cover holding the trigger and sync buttons on to get to the part. It may be molded onto the replacement - in which case, you will need to play with the adjustment a little bit to get it right but that may not be a problem on the 1708 since it’s designed as a split part on the factory sealed controller. The part is easily found on eBay. I don’t recommend used OEM parts as the factory spec plastic is too fragile and will break again.
Indice 3
2 commentaires:
Thank you! I figured there was no way in trying to fix it or replace it. so I went with your way and bought a controller for parts with the same model number and replaced it that way.
par
Just be careful if it's like the OEM parts that broke before. If it happens again, find a clone part to replace it. The space needed to use glue isn't sufficient.
par
Ajouter une réponse
Potato Sauce sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 560
