Aller au contenu principal
Pour réparer ensemble - Je crée un compte
A2116 / 2019 / Processeur i7 quadricœur 3, 3,0 GHz i5 à 6 cœurs ou 3,2 GHz 6 cœurs à 3,2 GHz. Commercialisé le 19 mars 2019.
after Upgrading my iMac 2019 the microfon did not work
after Upgrading my imac 2019 the inbuild microfon did not work..
I didnt remember what connector it was ?
have you any idee
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
2 commentaires
Nothing to do with a Imac 2019 27 '' I've found that the problem was the microphone itself, means that it's a HARDWARE PROBLEM.
par
Just try by using your headphone connected or iPods on bluetooth everythings work. So, i can concluded that it is an hardware problem.
par
Ajouter un commentaire
2 Réponses
Solution retenue
The microphone is well hidden!
What happened is when you put the adhesive strip down you plugged the hole in the case covering the microphone.
Here’s more details on properly installing the display Changement bandes adhésives iMac Intel 21,5" écran Retina 4K (2017)
Indice 3
2 commentaires:
Is this the same with the 5k iMac?
par
In my case i messed up real good.. the microphone in my 27 inches 5k 2019 is broken after upgrading the ssd.
the ribbon is very fragile
any idea how i can find the part?
Thank You !
Indice 0
1 commentaire:
Did you fix it? I just ordered one from thebookyard.com, hope it works flawlessly
par
Ajouter une réponse
Hans zen Ruffinen sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 43
Total : 3,361
