Mac slower after upgrading from i5 to i7!
Hey guys,
I’m baffled with this upgrade I did last week.
Upgraded my iMac 27in mid-2010 from i5 to i7 and also replaced original HD with a 2.5in 1TB HD (already installed a 500GB SSD as startup disk prior). I now experience some strange speed problems, when the fan kicks in my mouse freeze for a few seconds and then as the fans slow down I can move my mouse again, this happens very often since the upgrade and its like an advance warning when the fans turn on I expect to have my mouse frozen. Not only that but the mac itself seems to have this slowness everywhere, loading apps or running them.
All the upgrades were followed using iFixit guides.
3 reasons I can think of:
- CPU (tripled checked I bought the correct one, wouldn’t work otherwise)
- Thermal paste Artic MX-4 (could this cause this much problems?)
- Removal of the original HD which had temperature sensor that kept the fans normal, I now use SSD fan control.
Please help, not sure what I did wrong here, it’s driving me mad.
Regards.
Update (12/14/2020)
Update on this issue. I took @danj ‘s advice and separate the two drives apart, start-up SSD stayed where the original drive was and attached to the heat sensor (this was the reason for the loud fans turning on and off). Second drive moved to where optical drive was and as a test I unplugged the optical drive sensor and that drove the fan mad, plugged it back in and attached to the second drive for heat sensor and now everything works perfectly.
So keep those sensor plugged in and attached to the correct places.
5 commentaires
What is the exact CPU and its specs you put in?
par Dan
Intel Core I7-870 2.9GHz/ 8MB Socket LGA 1156
par Midge
Did you install the needed thermal sensor?
par Dan
No, it has 6 pins for the 3.5 HD not the 2.5 HD. I researched online and no one has problems with speed or mouse freeze at all even before installing SSD fan control app so I personally don't think that's the issue.
@danj oh wait, you said thermal sensor not heat sensor, yes I did reconnect it after taken out old CPU and double checked twice before I put the board back in the mac
par Midge
Thermal sensor VS Heat sensor that are the same!
par Dan
