Aller au contenu principal
In North America, the RX 330 series began sales in March 2003 for the 2004 model year.
Why does my Heat/Ac only blow air from the front Vent?
Hi, my 04 RX330 only blows air from the front vent. So it seems as though the heat and cold air are working as it is supposed to but when I try to switch the direction of the air flow it doesn’t switch. There is no AC/Heat by the feet or defrost. I’m in desperate need of the defroster working. Please Help and thank you in advance.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi @nas10 ,
It sounds as though there is a problem with the actuator that controls the direction of the airflow.
Here is the 2006 Lexus RX330 Service Repair Manual that should help you to find the problem (it should be the same for a 2004 model)
Scroll down and click on the Air Conditioning link.
Once you have the file open go to p.AC-12 to see how to test the actuator. Depending on the results go to p.AC-14 to see where it shows to check for the most probable cause of the problem. It points to other pages in the same file.
Hopefully this is of some help
Indice 1
2 commentaires:
Hi @jayeff,
i cant seem to open any of the pdf there.
par
Hi @nas10
Tonight I can't either.
I can't even get to the main website - cardiagn.com like normal.
maybe the website is having problems.
par
Ajouter une réponse
Nasir A. sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 14
Total : 1,372
