Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,2 GHz (Turbo Boost jusqu'à 3,4 GHz) ou 2,5 GHz (Turbo Boost jusqu'à 3,7 GHz) avec 6 Mo de cache L3 partagé.
20 questions Voir tout
Screen not working after replacement - external display works
Hi,
I recently replaced my MacBook pro's battery. When testing my screen didnt work, i get a distorted image. I tested with external displays and no problems there, that works just fine. So i tried with a new LVDS cable first but the problem remained. So i tried with a new display and i still got the samen distorted image. Where to look now? Is the LVDS connector on my logic board broken?
Thanks in advance!
Répondre à cette question J'ai le même problème
Indice 0
2 commentaires:
I would need to see things take a couple of picts of the distortion and post them here Ajout d'images à une question existante
par
@danj I added a picture!
par
Ajouter un commentaire
1 Réponse
Well, somehow the display got damaged in the process. The T-CON board which is within the lid at the bottom of the LDC panel. A common thing I have seen in the last few years is the excessive cleaning has killed many! What happens is people use a spray cleaner directly on the screen to clean it without knowing it the cleaner drips down wetting the small T-CON logic board so it gets corrosion damage! Here’s a good writeup on how the T-Con works Sony T-CON Training Manual
You’ll need to replace the display assembly to fix this Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2014.
The bad news is finding one! Lots of people are holding onto the older systems as either they meet their needs or they just don’t like the newer system’s (butterfly keyboard) & (lack of ports and no internal expansion). Keep an eye here or do your own search using the P/N 2013/14 - 15” MacBook Pro Display Assembly, Apple P/N 661-8310
Indice 0
7 commentaires:
Well, thats the weird thing; i already tried with a new display and the problem remains...
par
Is it the same pattern or just black?
par
@danj Thanks for your reply. Its the same pattern on another display.
par
Are you sure you got a good display? Did you replace the full display assembly or just the panel.
If an external display works, with the external still plugged in is the internal display now working?
par
@danj Yes, im certain i tried with a good panel. I replaced the entire display assembly. I even tested the current broken display on another system and it worked there. The external display works with the internal display on, but the internal display never works. It shows a distorted picture, no matter what.
par
Voir 2 commentaires en plus
Ajouter une réponse
Laurens Dierickx sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 64
