Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,4 GHz, 2,7 GHz ou 2,8 GHz (Turbo Boost jusqu'à 3,8 GHz) avec 6 Mo de cache L3 partagé.
20 questions Voir tout
Early 2013 MacBook 15" Retina display hinge replacement
Hi All,
I am trying to replace both broken hinges on my Early 2013 Macbook 15” Retina. I have all the necessary parts in hand and have separated the display from the body successfully. Now, however, I have hit a snag: I can find no disassembly instructions for removing and replacing what I believe must be the WiFi wire. Any links and/or tips? Thanks for any help!
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Sorry we don’t have a guide, all we have is this MacBook Pro Retina Display Teardown for reference.
Indice 1
15 commentaires:
Thanks! I only hope this doesn’t mean I have to tear the display apart to replace wires...
par
Yep! You do ;-{
The better direction is just replace the entire lid assembly 15" MacBook Pro Retina Display Assembly, Apple P/N 661-7171
par
Sadly, I fear you are correct. All for a 1/4" Retina connector that won't go through a lid hinge. Shame on Apple. And any display disassembly looks doomed to disaster. However, here's what I think I will do (less than optimal, but reasonable): I will try to untangle and keep the old Retina wire as well as the new replacement one. I might be able to adhere them adjacent to the laptop lid without cutting them. No more onboard camera, but everything else will work. If there only was such a thing as a male-to-male Retina plug adapter...
par
@dschind - As much as I would like to tell you that would work, it won't! The camera cable also carries a voltage and thermal sensor which if you disconnect will cause your systems SMC to throttle the CPU and ramp up the fan.
par
Thank you so much for your contribution! This has given rise to one other (maybe crazy) thought. What if I can succeed at prying apart the hinges themselves enough to swap new-for-old? Then I can leave the cabling untouched and functional. Very tricky at best, but...
par
Voir 10 commentaires en plus
Ajouter une réponse
dschind sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 8
Total : 500
