Aller au contenu principal
Sixth generation of Apple’s wireless base station, released June 2013. The tower provides dual-band support wireless access and is Apple’s first router with 802.11ac technology.
20 questions Voir tout
Can not reconnect cables to logic board?
I just opened my A1521 Airport Extreme to clean and lube the cooling fan, trying to solve the overheating problem. Everything has gone back together nicely until I got to the last step of connecting the two small connectors to the logic board. One of these goes to the indicator lamp, not sure about the other. After an hour of trying, I’ve had no success in getting the connectors to snap into place. The back of the connector is virtually smooth, so I don’t see how it is supposed to connect. It does not appear like the connectors broke when I removed them, but it seems like I’m trying to connect a smooth connector to a smooth surfaced circuit board. How are these supposed to connect?
Update (07/18/2021)
Dan, that’s exactly what happened, I can now clearly see that both parts of the connectors pulled off of the board. The tear down instructions gave several warnings about being careful to not break the connector, and I was impressed with how easily and cleanly mine came off. Perhaps I will add a comment about what happened here. I left the reset switch connected to the board, and instead disconnect the actual switch from the case. My problem is with the LED and whatever the other is directly next to the LED. What is that one?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
@charles218 post some pictures with your QUESTION of what your cables and board connectors look like. That way we can see what you see Ajout d'images à une question existante
par
Ajouter un commentaire
2 Réponses
Solution retenue
Ouch! It sounds like you lifted the logic board connector off with the cable connector!
Click on the image to enlarge
If that is the case you’ll need to see if your logic board can b fixed otherwise it’s time for a new one.
Indice 1
If I remember correctly, one is an LED and the other is the reset button, they should not be critical components. If you tore the connectors, leave them be.
Indice 1
Ajouter une réponse
Charles Larkins sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 114
