Power fuse. Where is it?
I’m trying to find the Power fuse im our Cafeo Solo.
Where is it placed? And what type of fuse is it?
All heating appliances must have thermal fuses to prevent a fire. They’re in line with the power inside the case clipped to the heating element section.
One version looks like a 3/16” diameter x 1/2” cylinder with an epoxy tapered plug in one end. One wire is attached at each end.
Another common version is a 1/2” diameter x 3/8” high can with 2 mounting tabs and 2 spade lugs for the wires.
I hope it has the rating marked, usually in Centigrade, otherwise you’ll have to find it. Thermal fuses are made in a wide variety of temperature ratings - it’s dangerous to guess it.
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 311
1 commentaire
@VauWeh any idea about this? @jannegus ,he is the coffee machine guru and wrote the guides for this model. The @ should notify him of your question. Let's see what happens
par oldturkey03
