My batteri wont charge
Hi,
I m trying to fix this old Macbook, I got. I have an MacBook 2012 aswell, and have two chargers, both are working with the 2012 so they shouldnt be the problem.
I bought a new battery to the mid 2010, and everything works perfectly, but the new batteri wont charge. But I can run the computer with one charger in it, that works great.
I have tried to reset the SMC, both with remove the batteri and hold down powerbutton for 10 sec, and left shift, ctrl, alt for 7 seconds and the power button for another 7 sec.
Which one is the correct way for my Computer? But none helps.
Is there anything else I can do?
Its an old drive in it so Im gonna change to SSD, and also change RAM, could that help someway? Newer OS?
Update (02/23/2022)
Ok, this is the image.
So I bought a new battery, when i came it only had 10% battericharge, when I was gonna check coconutbattery again now, my daughter(there for the destktopimage :) ) had used the computer without a charger. The charger has a green lightning but the computer didnt start at all. I saw a youtube movie earlier where they schratched the keyboardcontact? and this worked, but the fan went realy high. However I was able to take this picture.
But now I have the startproblem to deal with aswell….
6 commentaires
Have you checked coconutbattery to see what it’s saying about the battery?
par Jay C. Landgraf
No, I dont even know what it is. But I will check it out, thanks. Took for granted though that there was a new battery that i should work.
par Mr Magoo
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Ajout d'images à une question existante
par Dan
So what Im looking at. :)
Everything seems good to me.
macOS Battery status good
Loadcycles 1
Age 275 days..
However
Charging with 0 Watts
Power adapter Connected
par Mr Magoo
@Mr Magoo - Can you post the image so we can see it too!
par Dan
Afficher 1 commentaire en plus
