Apple logo for a second then blank upon startup
I replaced the battery and the trackpad on my 2015 retina macbook. Afterwards, when power is attached it does not boot however the power chime sounds, the apple logo and progress bar flash for a second then the keyboard lights up for a few seconds, then all goes dark and it’s dead. From the above symptoms, it appears that the keyboard, screen, power and speakers are connected but the system is not functional.
Any ideas?
What is the charger telling you? Amber or Green
par Dan
@danj This is not a macbook with magsafe btw.
Have you tried disconnecting the battery and then plugging in the charger as that should turn it on. If not then try disconnecting and reconnecting certain components as those could be taking power from other areas that need it more.
par Nick P
The USB-C charger has the LED
par Dan
@np_f1_2021 - be careful you don’t send someone down the wrong path. This system is tricky! You can’t run it from a charger alone without damaging it. Review this guide Remplacement de la batterie du Macbook Retina 2015
par Dan
Oh my bad sorry I haven't worked on these things before lol. Follow what @danj said as he is more experienced in this realm.
par Nick P
Voir 3 commentaires en plus
