Aller au contenu principal
Tutoriels de réparation et informations sur le démontage pour le MacBook Pro 14 pouces sorti en octobre 2021, équipé des SoC M1 Pro et M1 Max conçus par Apple. Modèle A2442.
55 questions Voir tout
Weird screen edge spot
Hi,
I just bought my first Macbook and as it`s great all over, I`ve noticed that on the top edge of the screen there are bright lines. Is it normal or should I be concerned? I`m thinking if it`s pay off the hustle to return it if there is a chance to get it again as (maybe) it`s not unusual.
Répondre à cette question J'ai le même problème
Indice 0
2 commentaires:
@jakubkn - I see a white line along the rubber gasket where the screen and metal edge meet up. Is that what you are noting?
If it is does this looks like light leaking out or is it some adhesive that squeezed out?
par
@danj Yes. Unfortunately it`s neither of that. It`s visible with screen turned off. Tried microfibre cloth of course, but it is more like cut or brushed that black layer at very end.
par
Ajouter un commentaire
3 Réponses
If it bothers you I would make the effort to get it fixed (they would likely replace the display) if you just got it then they would likely exchange the system out. I don't think this is a widespread issue, to be safe I would open the packaging up at the store and make a good inspection.
Indice 0
I believe this is a manufacturing defect, the black paint behind the glass has been scuffed off maybe by production fixture.
A tiny amount of paint scuffing off may allow light reflected across the front glass to leak out the edges.
Ask Apple if they would offer exchange or repair. It is possible that they will refuse citing this is just a cosmetic issue.
If Apple won't fix it for free, in my opinion this tiny defect is not worth fixing, since you'll need to replace the whole display, maybe just paint it over using a black sharpie.
Indice 0
Hi,
I have the same problem, did you manage to fix this?? Thanks, would really appreciate a reply please its driving me mad!!
Indice 0
Ajouter une réponse
Jakub K. sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 28
Total : 843
