Barre d'antenne
1 Réponse Indice de 1 |
Comment changer écran MacBook Pro 14" 2021 (M1) ? |
4 Réponses Indice de 1 |
MacBook Pro 14-inch M1 Not Charging via MagSafe or USB-C |
4 Réponses Indice de 5 |
How to remove keyboard keycap? |
3 Réponses Indice de 2 |
Backlight issue and firmware restore. |
Documents
Pièces
- MacBook Pro 14" (A2442, A2779, A2918) Battery
- MacBook Pro and MacBook Air (A2442, A2485, A2681, A2779, A2780, A2941, A2991, A2918, A2992, A3112, A3113, A3114, A3185, A3186, A3401, A3403) Key Caps
- MacBook Pro 14" (A2442, A2779, A2918, A2992) and 16" (A2485, A2780, A2991) Keyboard
- MacBook Pro 14" (A2442, A2779, A2918, A2992) and 16" (A2485, A2780, A2991) USB-C Board
- MacBook Pro 14" (A2442, A2779, A2918, A2992, A3401) Left Speaker
- MacBook Pro 14" (A2442, A2779, A2918, A2992) and 16" (A2485, A2780, A2991) MagSafe 3 DC-In Board
- MacBook Pro 14" (A2442, A2779, A2918, A2992) Lower Case Screw Set
- MacBook Pro 14" (A2442, A2779, A2918) and 16" (A2485, A2780) Battery Daughter Board Cable
Outils
- iFixit Precision 4 mm Screwdriver Bit
- Spudger
- Tweezers
- iFixit Opening Picks (Set of 6)
- Suction Handle
- iFixit Precision Bit Driver, Aluminum
- iFixit Thermal Paste
- TR8 Torx Security Screwdriver
- P5 Pentalobe Screwdriver Retina MacBook Pro and Air
- T5 Torx Screwdriver
- P2 Pentalobe Screwdriver iPhone
- T3 Torx Screwdriver
- Lint-Free Clean Room Wipes
- T6 Torx Screwdriver
- IA-3952 - Max Professional Consumable Isopropyl Alcohol
Modèles
A2442 (EMC 3650 MacBookPro18,3 2021) M1 Pro 10-Core/14-Core, A2442 (EMC 3650 MacBookPro18,3 2021) M1 Pro 10-Core/16-Core, A2442 (EMC 3650 MacBookPro18,3 2021) M1 Pro 8-Core/14-Core, A2442 (EMC 3650 MacBookPro18,4 2021) M1 Max 10-Core/24-Core, A2442 (EMC 3650 MacBookPro18,4 2021) M1 Max 10-Core/32-Core
Informations générales
Apple a entièrement repensé la gamme MacBook Pro fin 2021. Introduits aux côtés de nouvelles versions avancées de leur puce personnalisée M1, les nouveaux SoC M1 Pro et M1 Max intègrent respectivement des CPU 10 cœurs et des GPU jusqu'à 16 et 32 cœurs. Le nouveau MacBook Pro 14" et son grand frère, le MacBook Pro 16", marquent le retour de plus de ports, d'écrans mini-LED HDR ProMotion, de webcams 1080p avec encoche d'affichage, de touches de fonction pleine taille et d'un clavier au châssis noir caractéristique.
Disponible à partir de 1999 $, le MacBook Pro 14" 2021 est proposé en argent ou en gris sidéral.
Identification
Identifiez votre MacBook Pro grâce au numéro de modèle imprimé sur sa coque arrière.
Vous pouvez également trouver le numéro de modèle via macOS en choisissant À propos de ce Mac dans le menu Pomme dans le coin supérieur gauche de l'écran.
De plus, Apple propose un outil en ligne rapide pour vous aider à identifier vos appareils : Identifier votre modèle de MacBook Pro.
Le MacBook Pro 14" 2021 est identifié par le numéro de modèle A2442 / EMC 3650.
Réparabilité
L'indice de réparabilité initial d'iFixit pour le MacBook Pro repensé était de 4/10, mais il a été relevé à 5/10 après qu'Apple a publié publiquement son manuel de service et a rendu des pièces de rechange d'origine disponibles à l'achat pour les utilisateurs finaux.
Spécifications techniques
Écran
- Écran Liquid Retina XDR 14,2" mini-LED avec True Tone ; 3024 x 1964 pixels (254 ppp) ; taux de rafraîchissement adaptatif ProMotion (jusqu'à 120 Hz) ; HDR, large gamme de couleurs P3 ; 1000 nits en continu, 1600 nits de luminosité maximale
Processeur
- Apple M1 Pro CPU 8 cœurs 3,23 GHz, Neural Engine 16 cœurs
- (Configurable en) Apple M1 Pro CPU 10 cœurs, Neural Engine 16 cœurs
- (Configurable en) Apple M1 Max CPU 10 cœurs, Neural Engine 16 cœurs
Graphismes
- GPU intégré Apple M1 Pro 14 cœurs
- (Configurable en) GPU intégré Apple M1 Pro 16 cœurs
- (Configurable en) GPU intégré Apple M1 Max 24 cœurs
- (Configurable en) GPU intégré Apple M1 Max 32 cœurs
Stockage
- SSD basé sur PCIe de 512 Go, configurable en 1 To, 2 To, 4 To ou 8 To.
Mémoire
- 16 Go de mémoire unifiée, configurable en 32 Go (M1 Pro ou M1 Max) ou 64 Go (M1 Max)
Sans fil
- Réseau sans fil Wi-Fi 6 802.11ax ; compatible IEEE 802.11a/b/g/n/ac
- Technologie sans fil Bluetooth 5.0
Batterie
- Batterie lithium-polymère intégrée de 70 watts-heures
- Jusqu'à 11 heures de navigation web, jusqu'à 17 heures de lecture vidéo via l'app Apple TV
Dimensions
- Hauteur : 1,55 cm
- Largeur : 31,26 cm
- Profondeur : 22,12 cm
- Poids : 1,6 kg
Ports
- Port de charge MagSafe 3
- 3× ports Thunderbolt USB-C (Thunderbolt 4 / USB 4 / DisplayPort / charge)
- Port HDMI 2.0
- Lecteur de carte SDXC
- 1× prise jack 3,5 mm
Informations complémentaires
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Je commence à traduire ›
