Backlight issue and firmware restore.
Hi everyone,
I’m dealing with a frustrating issue on my MacBook Pro M1 (2021) and could really use some advice. Here’s the problem:
• The issue: The backlight on my MacBook has gone dark multiple times now. When it happens, I can only see the display using a flashlight, so the screen isn’t entirely dead. Sometimes, after doing resets (SMC, NVRAM, etc.) or powering down and restarting, the backlight comes back on, and the MacBook works normally for a few days, but then the issue returns.
• Recent problem: This time, the issue worsened. When I power on the MacBook, it chimes as usual, and the Apple logo briefly appears on the screen before disappearing. After that, it keeps trying to boot but eventually lands on a black screen with an exclamation mark, asking me to restore the backup. The device no longer loads into the startup options even when I hold the power button for recovery mode. I’m seeing all of this using a flashlight because the backlight isn’t coming on at all.
• What I’ve tried: I attempted a DFU restore, but I got a “MacBook can’t be restored, error 2006”. I’ve also had a technician check it out, and he found a circuit shortage in the display and SSD section of the logic board, which he claims to have repaired. However, the backlight issue persists, and now it won’t boot past the exclamation mark screen.
Next steps:
The technician is now considering replacing the display to see if that resolves it. My main concern is whether it’s a display issue or if the problem lies elsewhere, possibly with the logic board or some other component. I’ve heard that issues with the backlight IC or power supply could also cause similar problems, but I’m not sure how to proceed.
My questions:
1. Has anyone experienced similar issues where the backlight randomly cuts out and comes back after resets?
2. Could this still be a logic board issue even though the technician didn’t find anything else wrong after repairing the circuit?
3. If replacing the display doesn’t fix the problem, what other components should be checked (backlight IC, cables, etc.)?
Any advice or suggestions would be greatly appreciated. I’m really hoping this isn’t a permanent issue, and I’d love to hear from anyone who has dealt with this before!
Thanks in advance!
