Aller au contenu principal
Tutoriels de réparation et informations sur le démontage pour le MacBook Pro 14 pouces sorti en octobre 2021, équipé des SoC M1 Pro et M1 Max conçus par Apple. Modèle A2442.
20 questions Voir tout
Can I swap Silver Display Assembly for the Space Gray
Can I swap display assemblies of different colors within the same model?
Over the years, I have replaced many a Macbook Pro/Air display assembly. Occasionally, this has meant using an alternate color when the desired color was unavailable (ie: replaced a space gray with a silver one).
I just did such a swap with the 2021 Macbook Pro 14-inch (a2442), after being unable to locate a silver one to match the original one that was damaged. Now, it won't start. I followed all the standard procedures during the servicing (ie: disconnect battery, drain excess power, careful while "under the hood").
Obviously, I'm going to try and charge up the Mac . . . as soon as I can get my hands on the right charger. Until then, I just wanted to make sure this display assembly swap should work.
Thanks for any input. Off to find a charger.
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
4 Réponses
Réponse la plus utile
So sorry ;-{
You face two issues first you need to get a used display assembly as the Camera is calibrated for TrueTone support. Only Apple has the needed tool to do this. The second is Apple now serializes the displays with M series systems as well now.
Indice 2
3 commentaires:
Hi, is there some info in the web which Macbook pro/air products have serialized components? And what components are serialized? Many thanks.
par
@Janne Boman There might be. But that gives me an idea for a future project. There is definitely information scattered about, It's generally a safe bet that the display is serialized on any machine with a T2 chip (2018 and newer).
par
@flannelist - Great idea! Keep in mind the Intel T2 models can get a used display, new newer M models not.
par
If the screen is for the same model, color does not matter, it should work.
Indice 2
1 commentaire:
Almost! Sadly Apple serializes the M systems display so it’s mated to the given system!
So unless you get directly from Apple you are SOL. It makes no difference which color.
par
@danj well. . . It worked.
Indice 1
3 commentaires:
A M series can't without access to the calibration tool. A T2 based MacBook CAN use a used display! A virgin (factory fresh) display won't have the needed FaceTime firmware installed yet. So while the display will work the camera won't.
par
This explains a lot. I just bought a display from a 3rd party vendor, and he told me the screen was brand new, but my camera is not working. Is there a way to calibrate this screen myself? I have the M1 Silicon 2020 MacBook Pro.
par
@mangel90970 - Only Apple has the required tool and you can only get access by buying the part directly from Apple. The rub here is Apple has the server behind a pay wall and the displays S/N is your key to get access!
par
Hi
From what I know there is no reason why the screen shouldn’t be working as long as it’s the same screen for the model
I would try cleaning the isolated connector (both screen and board) to help clean away any microscopic dirt that our human eyes can see!
If this doesn’t fix the issue please don’t hesitate to ask
Indice 0
Ajouter une réponse
Chris Leeds sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 26
Total : 880
