Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La Galaxy Watch Active2 est une montre connectée de Samsung Electronics. Son numéro de modèle est SM-R825, SM-R830 ou SM-R835 et elle a été commercialisée en août 2019. Réparer votre Samsung Galaxy Watch Active2 avec ces tutoriels.
Watch stuck in reboot after possible water damage
I went into hot water with my watch, after i noticed that it kept opening samsung pay (like the top button was always pressed)
Now it keeps rebooting and doesn't turn on like the power button was pressed
Anything i can do?
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
8 commentaires
Can you press and hold the power button until rebooting comes up on the screen?
par Partager
It continues to appear even without pressing anything
par Partager
When rebooting appears press the power button a few times, hopefully another screen will appear. Use the power button to select recovery and then hold the power button to reset the watch back to factory.
Is there any signs of condensation inside the screen or the sensors on the back by the way?
par Partager
The Active watch 2 is supposed to be ‘waterproof’ to a depth of 50 metres. Also you are supposed to be able to wear it in the shower which is hot water. I wouldn’t open the watch just yet, I’d contact Samsung support and tell them their waterproof watch has water damage and ask for it to be replaced. As long as there is no damage to the screen or the back I can’t see them being able to say no. Unless you pressed one of the buttons whilst it was under water.
par Partager
@strongbow There were just signs of corrosion but no condensation. Cleaning everything made the watch work again
par Partager
Voir 3 commentaires en plus
Ajouter un commentaire
2 Réponses
Solution retenue
Hi,
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the watch's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your watch and then remove the battery as soon as possible from the watch to minimize any further damage.
Then you need to dis-assemble the rest of the watch and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the watch might possibly work correctly again.
Here the ifixit Samsung Galaxy Watch Active2 guide that may help
If this process seems too daunting, take your watch to a reputable, professional mobile phone or electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Indice 4
5 commentaires:
Thank you, this was very helpful.
When I opened the watch there were signs of corrosion like you said
I cleaned everything with isopropyl alcohol and now the watch works
I used some B-7000 to seal the watch, hope it is ok
par Partager
I went for a long shower and washed my hair with my Galaxy 2 on. It started going into reboot loop and couldn't get out. I had a sealed up pack of Sushi rice and threw it into a container with a lid and stuck my watch face down inside. Within about 15min my watch went back to normal and everything was still there. I almost couldn't believe that it worked!
par Partager
@claudia42069
I suggest that you back up the data on the watch, whilst it still works
You may have been lucky but it may start to fail in the next days or even weeks.
Using rice is a myth. It doesn't stop the corrosive effects of the impurities in the water damaging the components.
rice is for dinner, not repair
par Partager
@diegoferranti
I have the same problem. Also went to hot water then the top button was pressed and it started rebooting. Can you give me more information about where the corrosion was because i cleaned most of it but it is still showing rebooting.
par Partager
@reyanasad I did a general cleaning of the internals, in particular the buttons, for me it was enough but it came back a few times because after my repairs the watch wasn't really waterproof
par Partager
My Gear S3 did a similar thing when it got in the wash. I seemed to have been able to get it back to normal with the aid of CO2 computer duster used to evacuate water through the speaker holes and bezel, and then leaving it alone for 20 min until it booted up normally
Indice 1
1 commentaire:
So my galaxy active 2 watch went crazy when sweat got inside the case , now stuck in reboot loop so I took 91% alcohol and poured enough in a cup to submerge the watch , once the watch was dunked I wished it around for like a minute and hopefully it works right if not . Time for a new watch . Stay tuned
par Partager
Ajouter une réponse
diego ferranti sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 52
30 derniers jours : 109
Total : 34,287
