installed ifixit replacement battery wont connect power adapter
Hi People,
so I did the full (took apart everything) repair as follwing:
Remplacement de la batterie du MacBook Pro 15" Retina mi-2012
everything back together, everything works fine.
Except the magSafe plug wont show any light. The replaced battery wont charge, but it is running my macbook... now at 76% ... till there will be no more juice left...
While I was putting the macbook back together, I had medium struggle getting the cable connection coming from the new battery into the mainboard. After 3rd attempt with more and more pressure i relaxed my mind and it worked out easy.
I think all other connections should be ok. Also rechecked everything.
One more thing... I got twited memory... maybe i didnt turn the macbook off before... i dont know somehow :D
Do you think i should just buy the used i/o board with the power in for magSafe to speed up my repair time?
Do you think i need a new battery? I mean its working really good!
I need my second brain back quickly...
Please Help ! :)
All the best from Germany,
Marcel
3 commentaires
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Ajout d'images à une question existante
par Dan
Sorry for that...
par Marcel
I see you say you checked everything, but are you sure you didn't crush any of the connector pins and that it is seated correctly? I apologize if you indeed did go back and do this. Usually the best place to start any troubleshooting is by beginning with possible physical issues first.
par ryanhurtt827
