Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Petites machines à café automatiques de Melitta. Ces tutoriels peuvent également être utiles pour d'autres modèles Melitta et pour des machines à café automatiques Nivona, Siemens et Miele – les modèles ont une conception similaire.
Flashing Beans at startup and turns off
Hi, I have a Caffeo Solo coffee machine. The problem is that when I turn it on it makes a sound from the motor in the brewing unit for a couple of seconds then after maybe 5 seconds it start flashing through the bean lights, and after a few seconds it just turns off the machine. I cant find anywhere what that fault code means. I have stripped the machine and tested the microswitches but I cant figure out what is wrong.
Répondre à cette question J'ai le même problème
Indice 4
Ajouter un commentaire
7 Réponses
Réponse la plus utile
Melitta says: "The brewing unit may not be locked correctly. Unlock the brewing unit and lock it again. If the display still flashes, remove the brewing unit, reinsert it and lock it again."
You can also turn off the machine, take out the brewing unit and press the microswitch of the brewing unit on the top right with a tool. Then switch on. It may then be position correctly.
Indice 1
7 commentaires:
It doesnt help. I have connected wires over the microswitches so that the machine thinks the brewing unit is connected, but nothing helps. i would like to know what the symbol of beans means, if the brewing unit is not in place it gives the right faultcode, but when i connect it, it after a few seconds shows the flashing beans and then it shuts off.
par
Did you check the microswitches in the gear drive? See Changement du microrupteur du moteur de la Melitta Caffeo Solo . Even if they seem to work fine they might actually be broken and have to be replaced.
par
Yes i checked the microswitches, they seems to work. Im not sure if the starting position of the gear is wrong, but it shoul correct it and find the right position by the posittion of the "microswitch wheel", but it dosent turn the wheel more than a few degrees so the wheel never push the microswitches.
par
I'm running out of ideas. I remember a Melitta where I would have to change the motor itself.
par
Hey Hans..i have the same problem after i changed the grinding wheels. I did the same as you..tried the microswitches..but nothing changes. Did you solve your problem already?
par
Voir 2 commentaires en plus
Same issue and I think if not enough beans in grinder it also make a different noise during grinding process, I concluded flashing beans on screen no coffee to grind in machine
Indice 0
1 commentaire:
that's exactly what it was for me. I had for a few years the same problem. You can for example open the Machine and put some grinded coffe in the opening (left from Grinder) to "assist " the machine.
par
I am wondering how the grinder knows if there are any or adequate beans? I cannot see any sensors of any kind so how does it know if empty or full?
Indice 0
The machine measures the current to the grinder motor. If there are no beans in it, it does not draw as much current and the machine issues an error message.
Indice 0
The motor in the brewing unit faulty, replace motor.
Indice 0
1 commentaire:
please don't. That does not solve the problem
par
Hey,
I had a moment when my brain switched off and while I was making my coffee I pour the water into the bean compartment. I know, silly and I'm annoyed with myself but I can't turn back time.
I had some smoke/steam coming from it. I thought that changing the thermal fuse will help, as it's directly under the bean grinder, but it didn't help.
I tried to reset the coffee machine and did the descaling programme, but water comes out cold. When the cycle finishes then flashing beans comes back and machine turns itself off.
Any ideas what I should do next?
Indice 0
Hello guys!
I am looking for the solution.
What i did is that i wanted to clean my Melitta caffeo solo&milk machine. I open everything and put back in place. Now when i switch on it is in Integrated cleaning programme. And I can not get out of that program. When I switch on, i am getting power on lamp and grind lamp flashing on. Can not stop it. Tried different combination of buttons and it just doesnt work. Integrated cleaning programme - is what i found in manual.
Indice 0
Ajouter une réponse
hans sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 26
30 derniers jours : 90
Total : 9,711
