Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Processeur 1,4 GHz ou 1,6 GHz / SSD 64 Go ou 128 Go
Do I need to replace entire trackpad or just the brackets?
Macbook Air Late 2010: Trackpad. The mechanics of the trackpad only work correctly when pressed on the bottom right corner (it goes down and back up as expected). The bottom left corner is permanently depressed and cannot be pressed or clicked.
I am not sure if I need an entire new trackpad or if the issue can be corrected by replacing a part, such as the brackets and screws that iFixit sells. The trackpad works fine otherwise, especially using the "tap to click" function, which does not require depressing on the trackpad. However, I would still like to fix this issue.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
6 commentaires
I'm suspecting your battery is pressing on it. Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Ajout d'images à une question existante
par
I second @danj's comment; a swollen battery could be pressing on the trackpad from the bottom and keeping it from working. Definitely a good idea to take out the 10 Pentalobe screws on the bottom of the case and check the condition of the battery; you're looking for any that are pillowy and no longer flat.
par
Thank you both. I will take a look and follow up. Just ordered the tools I need from ifixit.
par
The battery was swollen. Once I replaced it, the trackpad functioned properly. Thanks again for your help. I appreciate it.
par
@Jose, Awesome! Congratulations on a successful repair and not having to replace your trackpad. :)
par
Afficher 1 commentaire en plus
Ajouter un commentaire
1 Réponse
Solution retenue
Here's the needed battery MacBook Air 11" (Late 2010) Battery and here's the guide Remplacement de la batterie du MacBook Air 11" fin 2010
If the trackpad its self is failing then here's the needed part MacBook Air 11" (Late 2010) Trackpad and the guide to put it in Changement trackpad MacBook Air 11" fin 2010
Image Replace the trackpad for a MacBook Air 11" A1370 Late 2010 laptop model.
Produit
$29.99
Image Replace the 4790 mAh battery compatible with MacBook Air 11" (2010). 35 Watt Hours (Wh), 7.3 Volts (V).
Produit
$49.99
Image MacBook Air 11" Late 2010 Batterie
Tutoriel
Difficulté :
Modérée
15 minutes
Image MacBook Air 11" Late 2010 Trackpad (pavé tactile)
Tutoriel
Difficulté :
Modérée
Indice 3
2 commentaires:
Just opened it up. Battery is swollen. Looks like I'll be ordering a battery.
par
@Jose - Don't forget to score the answer and accept it - You should be good once you put in the new battery. Enjoy!
par
Ajouter une réponse
Jose sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 19
Total : 351
