Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Repair guides and support for your Panasonic microwave.
model NN-SN966S Lost all control of the keypad exept Reset
First, out of the blue, the display screen showed the Power Level counting down repeatedly (P 10, P 9...) while at the same time the speaker was sending out a continuous beep, beep, beep.
When I unplugged the device for a couple minutes, then plugged the power cable back into the socket, the display came up flashing and showed 88:88. I pressed every button on the keypad and only the Reset button worked clearing the display and showed : and again none of the keys on the keypad worked.
Anyone have any ideas? I'm thinking maybe the keypad failed or possibly the microprocessor. Is this even fixable?
Répondre à cette question J'ai le même problème
Indice 8
13 commentaires
Did you find an answer. I have the exact same problem.
par
I, too, have this problem. Pressing Reset causes a beep and clears the 88:88 from the display. No other buttons beep or do anything.
par
Hi, I am having the same issue. Did you find a solution or just have to purchase a new microwave? Thanks!
par
I m having same issue
par
Same issue ...I got a new microwave and a couple weeks later plugged it back up just to see and it worked... worked for day and half then did it again.
par
Voir 8 commentaires en plus
Ajouter un commentaire
10 Réponses
Réponse la plus utile
SOLUTION OK, My Panasonic SN966S Microwave suddenly died yesterday. Also after 2.5 years of average use, it suddenly started beeping and cycling through power levels before going totally unresponsive. My wife was distraught at the thought of no microwave for the next 10 days. So I dissasembled it and was able to confirm it is the Membrane keypad that seems to have failed.
I wasn't able to remove the membrane keypad, and I had no replacement redily available. So I pondered what would be the next best thing. My wife would be happy if we could warm tea or vegatables, so we don't need all the fancy extra keys.
My best estimate was that one of the rows or colums was shorting out 100% of the time, causing the keyboard Matrix to no longer be readable by the CPU.
I guessed that if I was able to break the short open, all would be good. But that looked like a lot of work to attempt to hack open the mebrane and risk destroying it, and the aesthetics would not make my wife happy.
So I experimented, with a strip of mylar about 0.2 inches wide, I slipped it into the " CN5 " keyboard connector socket, and moved it through the 9 trace positions until I found a wire that I could disable, and bring the unit back to life.
To my surprise after 6 failed attempts the 7th position gave me a bit of happiness. By isolating the 7th trace ( counting from top to bottom ) on the flexible membrane cable, I was able to isolate the short and the microwave came back to life !
I admit its not " good as new" , the "2 shows up as a 3" and the "power level button no longer works :-) ) but for a penny and 30 minutes of your time, it lets us use it until if and when we decide to replace the keyboard with a new one.
Update (06/29/24)
Here are the picks of the mylar strip in white
Indice 9
14 commentaires:
Hi Steve - You are a genius! I had the exact same issue (Panasonic built in 2.5 year self destruct) followed your fix and it works. Not good as new, as you note, but the important parts work and the fix was free!
par
This JUST happened to me! I’ve never been in a microwave before. Do you have any pics of your repair or the Mylar you used? None are showing. Thanks!
par
Sorry, just saw the pic up top!
par
i tried this, and realized the contact is actually on the other side of the connector{ test gray color pin on mylar side, not white side} . easier way to test the pad is by remove it from the black clip and test the pad using a ohm meter, any resistance of anypins to other is a short (pad is shorted).
usually issue is the board
par
PS> when key pad is not pressed, all pins are normally open position. (no ohms showing between any of pins)
par
Voir 9 commentaires en plus
As it happens, I just fixed two of these - same problem on both. The problem is a poorly built (i.e. very cheap) keypad switch assembly. What you are looking at from the front is just a thin plastic cover (with the pads embossed on it). Behind that is the actual keypad, which is an array of small metal domes. They take very little force to depress, frequently deform, and eventually one "sticks." That is, it stays depressed, even when not touching the microwave front panel.
[You might could temporarily fix the problem with a hair dryer on low heat. Warm it up (without melting it) and it might pop back - Temporarily!]
The maintenance manual is available online from Panasonic. It's free, and almost worth the cost. You can buy replacement keypads from Panasonic and/or other dealers - about $40. Replacement requires no special skills, but a fair amount of patience. I am considering at least a quickie writeup on how to do it, given that the need is so common. Meanwhile, if you want to try it, please feel free to drop me a note with any questions.
Note: The "taping off" of one or more switch PCB connection may or may not work (depending on which switch is stuck). Worst case, wind up needing to replace the keypad, which you do anyway.
Indice 3
7 commentaires:
Yes, I see no sign that the newer keypads are ANY better than the originals. However, if your microwave is newer and more expensive than you want to toss into junk bin, then replacing the keypad is not expensive ($35 to $50 USD) - just a bit labor intensive. Or, if you are like me, you just like to "tinker" with things that should NOT be broken, then it's a fun little project. And you get another 1 - 3 years out of it. Pretty good return on investment (if you don't count your time).
If you decide to go for it, and have any questions, we are here to do what we can to help. jmk
par
Dear jknox: Thanks for the info. I have the same problem and the mylar is not fixing it. I may put in a new keypad. How long does that take? Any idea where I can see how the keypad comes out?
Thanks.
par
Update: I put fiberglass tape on both side of pin 7, stuck the ribbon connector back into the plug and voila. It works (somewhat): "3" reads as "2", "7" reads as "6", and power level button does not work, but this is all fine. Thanks a lot to everyone for posting about this.
par
@jknox92131 Would you please share some pointers for removing the metal trim to replace the membrane keypad? Does the whole black plastic part behind the keypad (that the circuit board clips into) need to be removed first? Is seems that the whole black plastic assembly should slide up to remove it, but it doesn't budge (maybe there is a screw somewhere I missed). I'd greatly appreciate any disassembly guidance you can offer to get the metal trim off to get to the membrane keypad.
par
I have resolved this problem by connecting the line cord to an outlet strip that has a switch. If your turn the switch off after normal use the control panel is reset and works normally. I had replaced this 9 year old Panasonic with a newer model 2.5 years ago, This newer model has an even worse malfunction. After removing the wave guide cover I can see that the antenna for the magnetron is charred causing severe intermittent arcing. Panasonic quality control has taken a plunge into subterranean depths. Future purchases of Panasonic> no mas!
par
Voir 2 commentaires en plus
Yes, Panasonic is aware of this faulty product, and has a solution. A chat with tech support today (9-12-2023) said "Yeah, those are symptoms of an internal component failing, unfortunately. Would you like me to look for a service center?"
My microwave, and dozens of other people's (read the unhappy 1 star reviews on Amazon) echo the exact same failure sequence. And they are not happy, because if it is out of the 1 year warranty-- so it's toast. For what I paid (over $350 with tax and shipping) it should have lived longer than 2 years and 6 months!
Indice 2
1 commentaire:
I had my unit fail twice this way. The first time was 12.5 months after purchase, and I convinced Panasonic to repair it even though it was 2 weeks past warranty. Then, 2 days ago, I was woken up at 4 am by the microwave counting down the different power levels and beeping non-stop, followed by a complete freeze of the keypad. I found this thread, and was so glad I did: the fix described worked perfectly. Yes, the 2 presses as a 3, the 6 as a 7 and the zero doesn't work, but given that the unit is built-in and finding another the exact size would be a lot of work, I'm happy to be able to heat my food for 1:59 instead of 2:00.
par
This exact same thing happened to me. Suddenly, the unit was beeping, and I looked and saw that it was counting down the power settings from power, 10 to power nine etc. etc. and then recycling… I found this string. JKnox’s Post inspired me to try something… I lightly tapped on the keyboard, striking the areas between the number pads and the other buttons… Several times… Apparently that loosened whichever button was stuck in the closed position and the keypad started working.
Indice 1
Thanks guys, our microwave, same model, decided to die at midnight and start counting down the power levels with the beeps. I suppose a new keypad will only last as long as the original, unless they have fix the issue.
Update (09/26/25)
I fixed mine yesterday. I replaced the membrane switch (Part # F630YBR60BAP). The PC board did not need replaced. The chrome surround needs to be removed which can be done by removing the PC board. It is held to the plastic housing by tabs and one piece of double sided tape just above the numerical display hidden under the chrome surround. The overlay and membrane switch are attached with sticky adhesive and need to be pried off. The replacement parts have the sticky back.
Indice 1
1 commentaire:
So, does the problem end up being the keypad or the PC board behind the keypad? I have the exact same symptoms but definitely want the power levels to work. I bought this microwave specifically for the power inverter feature. I like how it actually reduces cook power rather than cycle on and off.
par
@flasharoo since there are no schematics for the keypads, it might be difficult to repair those. From what you are telling us, it sounds like a bad keypad. Of course, check it for any obviously failed component and post pictures. That way we might identify what may have gone wrong. Ajout d'images à une question existante
Indice 0
I believe the problem is the timer or the ability to use the buttons to set the time!
88:88 That is what is displayed in the time window, when that happens no buttons
Work except reset!!!!!
Indice 0
FYI - Here is a link to a parts site that sells the replacement keypad assembly: https://applianceparts.com/item/10838409...
Indice 0
1 commentaire:
Did you need to replace just the keypad assembly, or also the pc board behind it?
par
Mine croaked a couple days ago. Thirty months since we bought it.
Guessed the Power button was shorted and saw the photo fix. We had been leaving it unplugged and only plugged it in to do 30 sec warmups, mostly coffee. Decided to take my keypad apart and removed the tin spring piece in the touch pad. Re assembled and no countdown like before but only RESET would work. I am not convinced a new touch pad would fix the problem, but until I can find a schematic. I suspect that the touch pads have an RC filter to prevent multiple signals from one press, a common problem on computer keyboards. I also found some solder splatter on the circuit board but after cleaning it all off, the problem continues.
The touch pad is available from several sources, including Amazon, so I'm not worried about finding one if/when I can be certain that is the problem.
Indice 0
3 commentaires:
I replaced just the keypad on mine, and it worked.
par
That is encouraging to know. Just ordered a new pad for mine. Meanwhile, any hints, suggestions, problems? How big a job was it?
par
"How big a job was it?" Well, that's a big crystal ball problem. The first one I did took probably five or six hours, being careful and also getting old adhesive off. [And spending a lot of time looking for "Why does it still not come off. Ah, there's another screw."] The second one too probably 20 minutes! <G>
Having the manual is a LOT better than not having the manual. But it is not well written, or as complete as it should be.
par
Do a hard reset
Indice 0
Ajouter une réponse
Harry Childs sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 70
30 derniers jours : 369
Total : 12,548
