Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Un ordinateur portable haut de gamme avec un châssis en aluminium et en fibre de carbone, fabriqué par Dell en 2018.
New 97w Battery Replacement - Not charging past 47%
Purchased a new battery to replace my current Dell branded 97w battery. The replacement was easy, however the battery is not charging past 47% (first time) and left on over night 18 hours. I did reseat again with not luck. Also, upon removal I performed that CMOS "flea" power clear holding down the power after battery removed for about a minute. Also, thinking this battery might actually be just a little thicker than original a I'm not getting a true click motion on my touchpad. Will most likely return and get a Dell original but thought I would ask here first. Really like what this company is doing and would prefer doing business here.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
Hi,
Create a battery report and compare the Design Capacity value versus the Full Charge capacity value.
For a new good battery they should nearly be the same value.
You may just have got a bad battery.
There is a 1 year warranty on the battery so if it is faulty getting a replacement should be no problem. Also explain about the "thickness" and the problem you think it caused. They may have got a bad batch who knows?
Indice 1
1 commentaire:
I have same problem, any solution?
par
Ajouter une réponse
Mark Willis sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 30
Total : 627
