Please help me with a rare green screen problem!
Hi! The screen of the MacBook pro 15 Retina 2014 turns green evenly every time after 5-10 hours of downtime. This is mostly visible at the edges, and when you look at the screen from an angle. After 10-15 minutes, the picture becomes normal. Are there any suggestions what the problem might be, and will this problem get worse? Now it doesn't bother me much, I just have to "warm up" the screen in the morning before work. Everything works well with the external display, the problem is clearly not in the video card. Maybe some kind of potentiometer is warming up for a long time? Maybe it's the anti-glare coating? Please help me, I can't find the answer anywhere.
Update (04/09/23)
I'm a little afraid to speak ahead of time, but here's an interesting thing I noticed. As a result, during the last week, I no longer had a green tint, and the screen works absolutely fine. A possible solution - I endured this problem for several months, it didn't get any worse or better. And a week ago, in a fit of nostalgia, I wanted to play GTA 4. I installed it via Bootcamp, set the settings to the maximum, not counting the resolution, and played for about 15 hours.
And that's it, after that, the green shade seemed to have disappeared forever. I hope so.
I don't know what the reason is, maybe somewhere something has warmed up, maybe possible moisture has evaporated, etc. But it obviously helped that the mac was under load, the coolers were noisy, the temperature was high.
I hope this will help someone else with a similar problem.
1 commentaire
par Alexandr Jee
