still having network issues after back glass replacement
even with the laser machine still having network issues. sim is still good tried that to make sure. so any idea what it could be?
Hi @joy99768,
There's always the chance of damage whenever you apply enough heat to the frame on the other side of a flex cable that's running along the metal, whether it's a laser or a heat gun. There are four main suspects that can all cause problems with wireless connections; it depends what you mean by "network issues". Here's a list of them; I'd replace the first two together to start with and if you still have issues then try replacing the next two.
Tutoriel
Difficulté :
Difficile
1 - 2 hours
Tutoriel
Difficulté :
Facile
5 minutes
Tutoriel
Difficulté :
Difficile
1 - 3 hours
Tutoriel
Difficulté :
Modérée
I would add the terminal screws and the mount points getting corroded on the frame as well as the cable ends.
I used a scratch pencil like these Scratch Brush Pen Set - Fiberglass, Steel, Brass, Nylon to clean things.
Just be careful with the debris as fiberglass will get into your skin irritating it and the metal can short things out. Tape off the area and clean your bench off well.
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 9
Total : 92
